AVOID_HIGHWAYS on xTour
i.kobeissy
Post by i.kobeissy »
Is there an equivalent to xRoute AVOID_HIGHWAYS (RoutingParameter) in xTour profile just like the usage of the <toll> tag in the dima profile ?
thanks
Re: AVOID_HIGHWAYS on xTour
Hello Ibrahim,
you can specify the "avoid highway" via profile xml:
The highways belong to the NETWORK CLASS 0 and therefore you can set the MalusByNetworkClass for the NC_0 to the malus value you need. The required key is
Routing/ Course/BasicDataRules/Network/MalusByNetworkClass
Check this minimal snippet: the key with the value 666 is the one you need:
<Profile>
		<Course>
			<BasicDataRules>
				<Network>
					<MalusByNetworkClass malus="666"/>
					<MalusByNetworkClass malus="10"/>
					<MalusByNetworkClass malus="15"/>
					<MalusByNetworkClass malus="35"/>
					<MalusByNetworkClass malus="40"/>
					<MalusByNetworkClass malus="90"/>
					<MalusByNetworkClass malus="100"/>
				</Network>
			</BasicDataRules>
		</Course>
	</Routing>
</Profile>
i.kobeissy
great, thank you for the quick answer,
I tried to find in the xTour documentation an explanation about all the NETWORK CLASS, but i couldn't find a place where all the eight classes are explained, can you help me with that please ?
Regards
Here's some helpful text...
https://xserver.ptvgroup.com/forum/view ... 2646#p2646
The classes are also listed in the xroute network class enumeration
