Historical speed patterns - route calculation too optimistic
I've made several tests using historical speed patterns and PTV test tool. What I could observe is that the calculated time for the example routes are too optimistic. Compared with results from Google maps, the results from PTV are always on the lower end of the Google results.
Example: A route from Märkisch-Buchholz to Berlin-Kreuzberg.
On Sunday, Google calculated time between 0h:40m and 1h:00m. PTV calculated about 0h:46m.
On Monday, Google calculated 0h:50m to 1h:25m. PTV calculated about 0h:52m.
It seems that PTV is moving along the lower ends of the Google calculation. My question: why is the upper value not taken into account? It's a significant difference between 0h:52m and 1h:25m.
Uli
Uli
Re: Historical speed patterns - route calculation too optimi
Hello Uli,
of course we depend on the data providers when it comes to those historical patterns. Most times I don't see such a big gap as mentioned by you.
What
What
- coordinates
- profile
- feature layers
here your requested data:
Coordinates: Starting point 1530170,06486812134,4859
the post was not complete, I accidently sent it.
Again, here the requested data:
Coordinates (format PTV_MERCATOR):
Starting point: 1530170,0648 6812134,4859
Destination point: 1491399,7297 6882788,3195
Profile: 'carfast' (refers to 'default' in the xroute profile configuration)
Feature layer: I'm not sure what you mean. Is it related to the 'Profile Snippet' to activate the histiorical traffic pattern?
Uli
Uli
did you have time to check my results?
Uli
Uli
Hello Uli,
I have to excuse - I might have overseen your post. But I'm back in the loop now. Looks like the gap isn't that big in the data.
If you wish to have a 1:1 websession get backto me so we can have a look at this scenario together (and at some more tools).
Regards
Regards
- Attachments
- test_wsc.xml
- Sample request. I change the RoutingParameter.START_TIME and RoutingParameter.START_TIME_ROADEDITOR via a loop.
- (3.91 KiB) Downloaded 634 times
Provider | min period | max period | min distance | max distance |
TOMTOM | 0:50:25 | 1:03:56 (+26.68%) | 56,76 km | 60,98 km (+7.45%) |
HERE / TLN | 1:06:03 | 1:13:16 (+10.93%) | 57.92 km | 61.03 km (+5.37%) |
in the meantime, the issue got a little bit out of sight from my side due to other projects. Nevertheless, I'm very interested in clarifying this issue and would like to take the offer of a 1:1 session. Can we schedule the session for the beginning of next week? Thanks a lot in advance.
Uli
Uli
OK, as discussed behind the scenes: here's the link for a GERMAN speaking session next Tuesday...
For those who check this post: feel free to join the session on July 10th, 2018 - 10am.
https://attendee.gotowebinar.com/regist ... 2942293249
here's the video...
and the snippet I used
Combine this with the RoutingOptions START_TIME and IS_DESTTIME to consider your current time scope.
<Profile>
<Course>
<AdditionalDataRules enabled="true"/>
</Course>
</Routing>
<Themes>
<Theme id="PTV_SpeedPatterns" enabled="true"/>
</Themes>
</FeatureLayer>
</Profile>
