Speed patterns: fixed time of day in profile setting?
michel_wsc
Post by michel_wsc »
I want to work with speed patterns (i.e. historical traffic data) for routing and I want to use a fixed time of day to be used for route calculation (e.g. 8:00am).
Is there a way to save this time parameter in any property file or profile?
Uli
Re: Speed patterns: fixed time of day in profile setting?
Hello Uli,
as far as I Know there are only two ways to specify the Date/Time context of a routing:
  • Via RoutingOption.StartTime
  • If RoutingOption.StartTime is empty the server's current date time is used.
I asked DEV to let me know whether there's a config value but I guess this isn't possible. I hope they correct me.
Hello Uli,
though I am a bit sceptic about the following approach I let you know it exists:
My colleague from the core team mentioned that you could use the High Performance Routing approach. As you might know the required SEARCH GRAPH is calculated based on a tool named RoutingNetworkGenerator (xServer1) and the command line options are
  • The profile name (incl. the names of potential feature layers such as PTV_TruckSpeedPatterns or PTV_SpeedPatterns)
  • The reference time that should be used for the snapshot "experience"
So if you create a searchgraph file based on those values you might be able to refer to a time context.
PS: xServer 2 provides a so-called SNAPSHOT mode which is also based on a reference time which has to be specified via API.
