Helo guys!
During an xRoute planning I've noticed a "badly" positioned road segment.
If I plan between the mentioned 2 points I receive a wrong distance value and that comes from the fact that the roads on the 2 border sides are not joined together.
StartLocation.Latitude = 54.270711;
StartLocation.Longitude = 25.375725;
EndLocation.Latitude = 54.274811;
EndLocation.Longitude = 25.378034;
Currently that problem doesn't affect my work much but I wanted to point you out that problematic part.
Oh and the map data is: EuropePremium_2014_2H.geo
Thanks,
K. Zsolt
Badly joined routes
Re: Badly joined routes
Hey!
There is a second example for the same issue:
start: 53.520969498, 23.658575337
end: 53.521946668, 23.66047848
Hope that helps!
Thanks,
Zs.
Hope that helps!
Thanks,
Zs.
Hello KZsolt,
thanks for the info - I forwarded it to some colleagues of the data department.
Usually such data corrections have to be forwarded to the data providers themselves, so it might take some time to be taken into account.
Regards from Germany,
Hello KZsolt,
meanwhile I've been in contact with our data experts ad they mentioned that we depend on our providers. Though the map you refer to is not proper we expect this effect to disappear in the upcoming versions. In the meantime the maps image might look suboptimal but the routing itself should work. See attached screenshot...
Best regards from Germany,
Helo!
Yes that doesn't affect the routing at all, just the calculated distance values. The difference is minimal (couple of hundred meters). Thanks for the reply, I'll check the fix in future versions.
Zsolt
Zsolt
