Hi all!
Is there any possibility to get the height data or height profile (above sea level) for a route or tour?
Thank you!
Height Profile
Re: Height Profile
If you set the resultlistoptions.polygonElevations to true the coordinates of the polygon will have set their Z attribute with the height above sea level.
Keep in mind that your map needs to contain height data (heights.bin file in the root directory of the map).
Re: Height Profile
