Today I was asked for the following situation:
- A customer has several boards in the same city.
- He uses the driver app.
- Depending on how he specifies the destination (cityname only versus postcode only) he gets different lists of potential arrival boards.
This is caused by the following business logic:
![[SearchRadius-DAVE.pptx].png (550.29 KiB) Viewed 75364 times The geocoordinates of the two input patterns are located in the same village but there is a small difference. The search radius in the app is set to about 3000m which is not configureable. (image is manually created so the radius may differ).](./download/file.php?id=667&t=1&sid=1d09fea16dd027bc6b0189d78a91c208)
- The geocoordinates of the two input patterns are located in the same village but there is a small difference. The search radius in the app is set to about 3000m which is not configureable. (image is manually created so the radius may differ).
![[SearchRadius-DAVE-2.pptx].png (1.08 MiB) Viewed 75357 times destination Yellow: one board (#1)<br />destination Blue: two boards (#1 and #2)<br />destination Orange: two boards (#2 and #3)<br />destination red: no hits at all](./download/file.php?id=669&t=1&sid=1d09fea16dd027bc6b0189d78a91c208)
- destination Yellow: one board (#1)
So by specifying the town center (blue example) the interface finds Board#1 and Board#2.
By specifying the postal code the result is : Board#2 and Board#3
