Dependency between matrix size and memory size
Karol.Korol
Post by Karol.Korol »
in PTV xServer Version 1.24 documentation we can read:
"The matrix should not be larger than 750x750 waypoints, otherwise PTV xRoute Server might run out of memory."
I like to know what is the dependency between matrix size and memory.
E.g.
how much memory should i have, to calculate matrix 2000x2000 waypoints or larger.
Is there a formula that will allow me to calculate memory size by myself?
Karol Korol
.NET Developer
karol.korol@4ls.pl
4LS sp. z o.o.
Złotniki, ul.Obornicka 52
62-002 Suchy Las, PL
http://www.4ls.pl
Re: Dependency between matrix size and memory size
Hello Karol,
at least within xDima and xTour the size of a Dima can be much bigger (no problem to computate 10'000 in square with high performance routing). I forwarded this question to DEV for a feedback,
Maybe you should consider to use the xDima - depending on your usecase.
Hello Karol,
I received an answer from DEV:
Let's compare a task of "700x700 routings". The temporary backend complexity with xTour, xDima and xRoute is probably almost on the same (eeeeeasy) level. But:
  • xRouteServer : if you request that size the response would contain about 500.000 XML nodes. The webserver will not be able to handle that document complexity and size.
  • xDimaServer / xTourServer: in these cases the dima itself isn't transferred to the client - just some data (plan, tours, ...) that are based on the distances. Of course a single xDima.getDistPeriod with the 500.000 would also crash but here you could slice the load easily.
OK with that explanation?
Karol.Korol
Thank you for your answer.
But how does it look when I use JSON data model? During the one of webinar ("PTV xServer - functional overview routing topics") you showed the calculation of matrix 2kx2k. You used xRouteServer or xDimaServer / xTourServer?
Karol Korol
.NET Developer
karol.korol@4ls.pl
4LS sp. z o.o.
http://www.4ls.pl
Hello Karol,
for the demo of HighPerformanceRouting I'm always using the xTour testclient with all planing functions being disabled.
I think the JSON interface would cause the same complexity. I doubt this is going to work.
