Hello guys,
Can a high-performance network generation calculate with one or more exception path?
If we would like to use high-performance network when calculating a request can we add one or more additional exception path in the request and still use the high-performance network?
Thanks in advance
BR
Daniel
High performance profile with exception path
biro.daniel
Re: High performance profile with exception path
Hello Daniel,
High performance routing cannot work with exception paths. One requirement for high performance routing is a fix set of options, adding an exception path will violate this requirement. xRoute will the automatically fall back to conventional routing.
If the path you want to avoid is stable you can use map and guide to create a custom blocking layer. The graph generator can take one blocking layer into account when creating a graph. If your exception path is dynamic however this is not a viable solution.
With regards,
With regards,
