Resolution/.Net window Issues
Clement.Sorriaux
Post by Clement.Sorriaux »
One of our customer gets display issues when he tries to display a map from our .NET object (wpf).
When he requests for a map, the map is correct but the windows for his application is moved on the side or completely reduce, the menu of this application is also impacted :
This behavior appears with the resolution 1900*1080 not below, do you have an idea on this topic ?
As you can see in the top of the picture (attached to the post), the menu is doubled (no it’s a desktop, it’s their application, all in blue :)) ).
feel free to ask for any further information you might need.
best regards
Clément
Oliver Heilig
Re: Resolution/.Net window Issues
Post by Oliver Heilig »
Hello Clement,
the map itself is just a control. It doesn't change the layout of the host window. For me it looks like the map is presented in an own window, and this changes the layout of the host-application window (in this case incorrectly).
Oliver
Oliver Heilig
PTV GROUP - Germany
Clement.Sorriaux
Hello Oliver
Sorry for the delay, I didn't get any notification about your answer, I'll check my forum parameters.
Thanks for your answer, I'll keep you posted if any other question pops out.
have a good day and thanks again
Clément
Clement.Sorriaux
Hello Again Oliver,
I asked to Bernd Welter if I could send them the xrouteToll application, they wanted to copy a functionnality available in it.
This behavior also happens with the xroutetoll application when the map is generated.
I don't know how this happen but I never got this issue on my side.
can It help to know where this issue is from ?
Which information could be useful to find the source of this issue ?
Clément
