Hi to all,
do you know how the "StopPositionInTour" parameter is running? What is his exact function?
If you specify this parameter in the request in anycase the ETA is calculated based on the order of the stops inserted and it seems the parameter is not taken into consideration.
Thank you in advance and Best Regards,
Daniele
StopPositionInTour
StopPositionInTour
Daniele Perella
Solution Engineer
PTV ITALIA Logistics
Solution Engineer
- Olaf.Neumann
Re: StopPositionInTour
Hi Daniele
unfortunately there is a bug in our implementation and theefore the parameter StopPositionInTour doesn't work currently.
The only way to change currently the stop order in a tour will be rearranging stops in this array.
Olaf
Olaf
Dr. Olaf Neumann
Manager Logistics Transport Real-Time Applications
PTV GERMANY
PTV GERMANY
