xMap 2.10: new features!
Posted: Fri Nov 30, 2018 1:38 pm
Here's a list of the new features implemented in xMap 2.10:
- The query parameters ‘mapLanguage’ and ‘contentType’ in the REST-API are no longer experimental
- The Feature Layer ‘PTV_TruckAttributes’ supports restrictions for vehicles with trailer exceeding a given length or width
- The attribute ‘mappingProfile‘ has been renamed to ‘renderingProfile‘. It has been revised completely and is no longer experimental. Please use the revised profiles in the folder conf/profiles/rendering/featurelayer.
- Furthermore the use case of the profiles is now called ‘rendering’ instead of ‘mapping’.
To make it more easy for you to react to the adjustments of the experimental API, we provide a FromMappingToRendering PDF document with all the changes
