xServer .NET Mapcontrol with proxy
KasperD
Post by KasperD »
Dear all,
One of our customers is using a proxy for all outbound connections within its organization. They've already managed to configure xRoute server to use the proxy for calculation, and they also wish to configure the xServer .NET Mapcontrol to use this proxy. However, they're struggling with the configuration for this and so am I.
Is there any way to do this?
Thanks in advance,
Re: xServer .NET Mapcontrol with proxy
Post by Oliver Heilig »
we don't have a way to set a proxy for the requests the control makes explicitly. The control uses the default proxy settings of the system, which is the configuration used for IE.
However you could configure a global proxy inside the app.config of the program
https://docs.microsoft.com/en-us/dotnet ... k-settings
I haven't tested this, but it should work with the control also. If not, please add an issue here https://github.com/ptv-logistics/xserver.net/issues
Oli
KasperD
Post by KasperD »
Oliver,
Thanks, i'll forward the info to the customer :)
did it work ;-) ?
I Was asked something similar by another partner today - thank god we have the forum!
