xServer2 calculateRoute "avoid" - parameters
Posted: Thu Sep 27, 2018 8:05 am
by Eratosthenes
On a xServer1 i need to call the "calculateExtendedRoute" function to calculate a route.
If i submit my request as json i have the "options" field where i can put values for:
avoidTollRoads
avoidVignetteRoads
avoidHighways
Where can i set these parameters in a json request for xServer2?
Seems like these options are here spread around the "requestProfile" -> "routingProfile" fields.
For example: it looks like the "options" -> "avoidUrbanAreas" parameter in xServer1 can set in
"requestProfile" -> "routingProfile" -> "course" -> "urbanPenalty" in xServer2
Is this correct?
If so: where can i find the other avoid-parameters?
Like avoidVignetteRoads and avoidHighways.
Re: xServer2 calculateRoute "avoid" - parameters
Posted: Thu Sep 27, 2018 8:21 am
Hello Eratosthenes,
from xRoute1 to xRoute2 we changed some of the basic approaches:
- xRoute1 offered explizit "parameters" such as the RoutingOptions and the possibility to create an XML document which was injected via snippet (CallerContextProperty) or stored on the server.
- For the parameters you refer to xRoute2 does not use explizit parameters anymore: you have to use the generic XML approach which appears in the abstract base class RequestBase : http://xserver2-europe-eu-test.cloud.pt ... equestBase
- Within the RequestBase you can specify the name of a stored profile (=XML dokument stored in the server wher you just mention the name) or set the property "request profile" which offers the RequestProfile : http://xserver2-europe-eu-test.cloud.pt ... estProfile
And voila: within the RequestProfile you can see the attributes: watch out for "penalties".
"$type": "RouteRequest",
"scope": "globalscope",
"storedProfile": "default",
"requestProfile": {
"routingProfile": {
"course": {
"toll": {
"tollPenalty": 2152
"distanceTimeWeighting": 40
"waypoints": [
"$type": "OnRoadWaypoint",
"name": "Waypoint #0",
"location": {
"$type": "OnRoadRouteLocation",
"coordinate": {
"x": 6.22029,
"y": 49.61513
"name": "Waypoint #1",
"location": {
"coordinate": {
"x": 6.06479,
"y": 49.62127
"name": "Waypoint #2",
"location": {
"coordinate": {
"x": 6.16479,
"y": 49.62127
"name": "Waypoint #3",
"location": {
"coordinate": {
"x": 9.26479,
"y": 49.62127
"routeOptions": {
"geographicRestrictions": {},
"polylineOptions": {
"elevations": true
"emissionOptions": {},
"routingType": "CONVENTIONAL"
"resultFields": {
"waypoints": false,
"legs": {
"enabled": true,
"polyline": false,
"tollSummary": true,
"emissions": false
"segments": {
"enabled": true,
"emissions": false,
"polyline": false,
"descriptors": true,
"roadAttributes": true
"nodes": false,
"polyline": false,
"tollSummary": false,
"emissions": false,
"report": false,
"encodedPath": false
Posted: Thu Sep 27, 2018 11:59 am
by Eratosthenes
So if i want several checkboxes in my user interface to give our customers the ability to:
avoidTollRoads
avoidVignetteRoads
avoidHighways
avoidFerries
avoidResidentsOnly
avoidUrbanAreas
avoidRamps
avoidLowEmissionZones
i need to create a profile for any possible combination?
By the way: we use your xServer internet. So which profiles are available?
Posted: Thu Sep 27, 2018 12:29 pm
Hello Eratosthenes,
it's easier than expected:
You can set these values at runtime. Check line #9 and #11 here:
"requestProfile": {
"routingProfile": {
"course": {
"toll": {
"tollPenalty": 2152
You can easily add further penalties if you want. As they are optional I didn't add all of them in my sample.
PS: xServer Internet:
https://xserver2-europe-eu-test.cloud.p ... n%7C_____6
You can check the available profiles over there. CLick on "profiles" manually.
Posted: Thu Sep 27, 2018 1:28 pm
by Eratosthenes
So if i want to avoid highways or vignette-roads i need to set the
requestProfile -> routingProfile -> course -> network -> penalties
parameter?
I see the default value is 0,0,0,0,15,50,100,100
i dont find any documentation about which integer means what.
Is there an explanation about the order and meaning of each single integer?
Posted: Thu Sep 27, 2018 1:43 pm
Argh, looks like the PTV colleagues are "user blind" - as we use those parameters almost every day.
A penalty value itself describes how attractive / distractive a segment class is, here's the text that appears when you hover over the Penalty text:
Defines the segment-specific penalty values in percent for controlling the course of the route based on special needs. There are two special penalty values: 2501 blocks all segments with the property in question (e.g. toll roads), and -99 prefers them over all other segments. Use a value in between to increase or decrease the mathematical cost for the segments in the routing algorithm. Use a positive value to increase the initial mathematical cost of the segment and a negative value decreases the cost by the given percentage. For example, 100 increases the costs by a factor of two and -50 decreases the costs by a factor of two. 2500 is the proper value when segments must not be used unless there is no other option (consider a ferry being the only way to leave an island, residential areas at start or destination). Range: -99 ≤ value ≤ 2501.
So this data type appears at several places of the API.
The eight elements of the int[] refer to the 8 different
network classes (
http://xserver.ptvgroup.com/fileadmin/f ... %7C_____14]) described as:
- MOTORWAY
- HIGHWAY
- TRUNK_ROAD
- COUNTRY_ROAD
- CITY_ROAD
- RESIDENTIAL_ROAD
- SPECIAL_ROAD, driveable but normally blocked
- CYCLE_AND_WALKWAY
So for example
"0,0,0,0,15,50,100,100" means:
- no extra handling of NC_0, NC_1, NC_2, NC_3
- an additional cost malus of 15% for CITY ROADS
- an additional cost malus of 50% forRESIDENTIAL ROADS
So from my perspective: if you want to avoid HIGHWAYS you could apply a malus value for the NC_0 and NC_1.
For the vignettes I have to ask some colleagues:
TOLL and VIGNETTE are two different topics:
- For toll roads you could use routingprofile.Toll.tollPenalty.
- For vignette I don't see the right property.
I'll forward the case to DEV.
Stay tuned,
Posted: Thu Sep 27, 2018 3:11 pm
by frs
Hi Eratosthenes, hi Bernd,
unfortunately at the moment we don't support avoiding roads that require a vignette in xServer2. I hope that this feature will be added in one of the upcoming xServer2 versions. In the current draft for future API we have modeled the vignettePenalty besides the tollPenalty.
Frank
