Couldn't parse stream
Posted: Thu Nov 06, 2014 11:00 am
by KZsolt
Hello guys!
Somethimes when I plan with PTV I recieve a "Couldn't parse stream" error. Do you have any suggestions what can cause that issue?
Thank you,
K.Zsolt
Re: Couldn't parse stream
Posted: Fri Nov 07, 2014 1:31 pm
Is this an error the xServer produces, or you own software?
If the xServer produces the error I would recommend to set your request logging to exceptional (conf/xserver.properties -> logRequests=exceptional ) and wait for the error to happen. After the error occurred you can contact support for further investigation. Do not forget to include a copy of the conf and logs files, and report which versions you are using.
If your own software produces the error you need to look into your code what triggers the error message. My best guess would be that you either hit a maximum size limit somewhere or your expecting a value somewhere witch isn't there. Last is most common in case a route has no size (start & end are the same, no intermediate points.
Posted: Fri Nov 07, 2014 2:36 pm
by KZsolt
Thanks for your ideas Joost!
xServer produced that error.
I'll try to save the log files next time I face that issue. Currently I can't send any relevant document, sorry.
