What is the proper rate for GPS position updates?
Posted: Fri Apr 27, 2018 10:51 am
a customer of mine wants a recommendation for the GPS position update frequency.
As far as I know it doesn't make sense to perform those updates every few seconds.
Is there any generic recommendation for the update interval?
Does it make a difference whether we check
  • a long distance tour between cities
  • a last mile tour with few hundred meters between hundred stops
Re: What is the proper rate for GPS position updates?
Posted: Fri Aug 23, 2019 1:39 pm
by Michael.Hubschneider
We would recommend to send it every minute (driver app also sends it every minute)
Beneath more frequent updates of ETA This assures better automatic recognition of drive&rest periods taken by the driver.
Up to 3 minutes is also quite good
Important is, that you start delivering GPS positions, when the tour starts, you can get effects in the ETA if the driver turns on his device later, as we assume, that is the point, where he starts driving, and use it in the drive&rest periods calculations
