I'm currently testing around with calculateAdvancedTour. I Need to use this as I need both toll Information and regarding driving regulations. Currently, XServer is not reachable, I will provide examples as soon as I can.
Key question: How can I notice and handle additional time and distance for linking ?
Input: a list of 4 waypoints. One of them is a Point I chose from a map, so it is not connected exactly to a road.
Targeted result: List of waypoints, with driving distance and time from each Point to the next.
In the Response, I now see several Information, but I am struggling in putting them all together.
- Route-info-distance contains the overall time and distance including linking.
- the array of tour events shows a timestmap of start and end as well as the period, which seems to include linking as well
- the array of stations contains accumulated distance and time, with time meaning from tour start to Arrival, without linking, breaks, Service, ...
I started doing the maths:
Distance from Station A to B = ACC_DIST of Station B - ACC_DIST of Station A --> 33638m
Driving time from Station A to B = ACC_TIME of Station B - ACC_TIME of Station A - Service period --> 3232 sec
Doing this for the whole tour, I ended up in this table:
| Station | ACC_TIME | ACC_DIST | Service period | dist from prev | time from prev |
| A | 0 | 0 | 0 | 0 | 0 |
| B | 3232 | 33638 | 1000 | 33638 | 3232 |
| C | 7747 | 74696 | 1600 | 41058 | 3515 |
| D | 13822 | 144388 | 200 | 69692 | 4475 |
| SUM | 2800 | 144388 | 11222 |
Comparing my results (sums) to values of Route-Info, I recognized it gives time="14102" and distance="145188" There is a difference of 800m / 80sec. This may seem as a very tiny difference, but nevertheless, as my tours can have a lot of stations, the error keeps growing bigger with each one added.
I only found in the tour events that driving from Point A to B lasts 3272sec and not 3232sec as I calculated, and from C to D it is 4515sec instead of 4475 seconds.
By the way, in the Country Infos, while distance="144388" which is equal to my calculations, but time="13822" , which is the third possible value...
This leads me to the following questions:
- How can I recognize if a linking distance and time has been added to the stations? The only way seems to compare sum with the header Information
- Does the ACC_* values in the waypoint array also include the linking?
- Does the toll distance also include possible linking differences?
Here's the request:
<soap-env:Envelope xmlns:soap-env="http://schemas.xmlsoap.org/soap/envelope/">
<soap-env:Header>
<n0:CallerInformation xmlns:n0="http://www.sap.com/webas/712/soap/features/runtime/metering/">
<m:Type xmlns:m="http://www.sap.com/webas/712/soap/features/runtime/metering/">SA</m:Type>
<m:Company xmlns:m="http://www.sap.com/webas/712/soap/features/runtime/metering/">0020630452</m:Company>
<m:Sys xmlns:m="http://www.sap.com/webas/712/soap/features/runtime/metering/">XH1_200</m:Sys>
</n0:CallerInformation>
</soap-env:Header>
<soap-env:Body>
<n1:calculateAdvancedTour xmlns:n1="http://types.xroute.xserver.ptvag.com" xmlns:prx="urn:sap.com:proxy:XH1:/1SAI/TAEF77083FD8061B8ACA5BE:740">
<n1:ArrayOfWaypointDesc_1>
<n2:WaypointDesc xsi:type="n2:TourPointDesc" completeServiceInIntervals="true" fuzzyRadius="0" linkType="NEXT_SEGMENT" xmlns:n2="http://xroute.xserver.ptvag.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<n2:wrappedCoords>
<n3:Point xmlns:n3="http://common.xserver.ptvag.com">
<n3:point x="9.6128079999999994E0" y="4.9860455000000002E1"/>
</n3:Point>
</n2:wrappedCoords>
</n2:WaypointDesc>
<n2:WaypointDesc xsi:type="n2:TourPointDesc" completeServiceInIntervals="true" servicePeriod="1000" fuzzyRadius="0" linkType="NEXT_SEGMENT" xmlns:n2="http://xroute.xserver.ptvag.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<n2:wrappedCoords>
<n3:point x="9.9420249999999992E0" y="4.9787083000000003E1"/>
</n3:Point>
</n2:wrappedCoords>
</n2:WaypointDesc>
<n2:WaypointDesc xsi:type="n2:TourPointDesc" completeServiceInIntervals="true" servicePeriod="1600" fuzzyRadius="0" linkType="NEXT_SEGMENT" xmlns:n2="http://xroute.xserver.ptvag.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<n2:wrappedCoords>
<n3:point x="9.7799750000000003E0" y="4.9490901999999998E1"/>
</n3:Point>
</n2:wrappedCoords>
</n2:WaypointDesc>
<n2:WaypointDesc xsi:type="n2:TourPointDesc" completeServiceInIntervals="true" servicePeriod="200" fuzzyRadius="0" linkType="NEXT_SEGMENT" xmlns:n2="http://xroute.xserver.ptvag.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<n2:wrappedCoords>
</n3:Point>
</n2:wrappedCoords>
</n2:WaypointDesc>
</n1:ArrayOfWaypointDesc_1>
<n1:TourOptions_2 restrictToSingleOperatingInterval="false"/>
<n1:ArrayOfRoutingOption_3 xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
<n1:ArrayOfExceptionPath_4 xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
<n1:ResultListOptions_5 binaryPathDesc="false" boundingRectanglesC="0" boundingRectanglesOffset="0" brunnelManoeuvres="false" detailLevel="STANDARD" dynamicInfo="false" manoeuvreAttributes="false" manoeuvreGroups="false" manoeuvres="false" nodes="false" polygon="false" segmentAttributes="false" segments="false" texts="false" tollManoeuvres="false" totalRectangle="false" urbanManoeuvres="false"/>
<n1:CountryInfoOptions_6 allEuro="false" calculatePartTollCosts="true" detailedTollCosts="false"/>
<n1:CallerContext_7>
<n4:wrappedProperties xmlns:n4="http://baseservices.service.jabba.ptvag.com">
<n4:CallerContextProperty key="CoordFormat" value="OG_GEODECIMAL"/>
<n4:CallerContextProperty key="ResponseGeometry" value="PLAIN"/>
<n4:CallerContextProperty key="Profile" value="truckfast"/>
</n4:wrappedProperties>
</n1:CallerContext_7>
</n1:calculateAdvancedTour>
</soap-env:Body>
</soap-env:Envelope>Code: Select all
<?xml version='1.0' encoding='UTF-8'?>
<soap:Body>
<ns4:calculateAdvancedTourResponse xmlns:ns6="http://exception.core.jabba.ptvag.com" xmlns:ns2="http://baseservices.service.jabba.ptvag.com" xmlns:ns4="http://types.xroute.xserver.ptvag.com" xmlns:ns3="http://xroute.xserver.ptvag.com" xmlns:ns1="http://common.xserver.ptvag.com" xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com">
<ns4:result genuineWaitingPeriod="0" defermentPotential="2147483647" remainingPeriods="22 serialization::archive 9 0 2 0 0 1 4 0 4 0 0 0 0 4898 0 0 0 0 11302 0 14102 152229 0 0 3 2147483647 2147483647 2147483647 0 0 0 0 14102 0 0 0 11302 152229 0 11302 152229 0 11302 757029 0 0 6 0 0 0 138127 0 0 0 0 0 0 0 0 0 3 0 0 1522174629 2147483647 0 1522174629 0 0 0 4 0 0 0 0 0 0 0 2 0 0 2 0 0 0 0 0 4 0 0 0 0 4 0 0 0 0 0 6 1 16200 900 1800 1 39600 10800 32400 32400 3 32400 36000 2 604800 86400 1 518400 201600 162000 324000 345600 0 1800 2700 21600 32400 900 28800 172800 39600 0 0 0 0 0 0 0 0 0 0 900 19800 28800 39600 0 25200 86400 43200 0 86400 604800 259200 900" tourPeriod="14102" startTime="2018-03-27T14:22:07Z" isViolated="false">
<ns3:wrappedCountryInfos>
<ns3:CountryInfo additionalInfo="" countryCode="" currency="EUR" iuCode="49">
<ns3:partRouteInfo cost="47292" time="13822" distance="144388"/>
<ns3:wrappedPerNCRouteInfo>
<ns3:RouteInfo cost="45717" time="2153" distance="45717"/>
<ns3:RouteInfo cost="0" time="0" distance="0"/>
<ns3:RouteInfo cost="1575" time="8600" distance="88297"/>
<ns3:RouteInfo cost="0" time="2371" distance="6007"/>
<ns3:RouteInfo cost="0" time="473" distance="2967"/>
<ns3:RouteInfo cost="0" time="225" distance="1400"/>
</ns3:wrappedPerNCRouteInfo>
<ns3:wrappedPerTypeTollDistance>
<ns0:Int>0</ns0:Int>
<ns0:Int>47600</ns0:Int>
</ns3:wrappedPerTypeTollDistance>
<ns3:wrappedPerTypeTollPrice>
<ns0:Int>638</ns0:Int>
</ns3:wrappedPerTypeTollPrice>
<ns3:wrappedTollCostInfos xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns3:CountryInfo>
</ns3:wrappedCountryInfos>
<ns3:wrappedPartTollCosts>
<ns3:PartTollCosts distance="0">
<ns3:wrappedCosts/>
</ns3:PartTollCosts>
<ns3:PartTollCosts distance="1800">
<ns3:wrappedCosts>
<ns3:TollCost type="NATIONALTOLL" iuCode="49" currency="EUR" cost="24"/>
</ns3:wrappedCosts>
<ns3:PartTollCosts distance="45800">
<ns3:wrappedCosts>
<ns3:TollCost type="NATIONALTOLL" iuCode="49" currency="EUR" cost="614"/>
</ns3:wrappedCosts>
</ns3:wrappedPartTollCosts>
<ns3:route>
<ns3:wrappedBoundingRectangles xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns3:info cost="121421" time="14102" distance="145188"/>
<ns3:wrappedManoeuvreGroup xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns3:wrappedManoeuvres xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns3:wrappedNodes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns3:wrappedSegments xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns3:wrappedStations>
<ns3:WayPoint countryCode="" wayPointType="START" manoeuvreIdx="0" segmentIdx="0" nodeIdx="0" polyIdx="0" iuCode="49" accDist="0" accTime="0">
<ns3:locationCoord>
<ns1:point y="49.860429025" x="9.6127714168"/>
</ns3:locationCoord>
<ns3:matchCoord>
<ns1:point y="49.856859832" x="9.6129444298"/>
</ns3:matchCoord>
</ns3:WayPoint>
<ns3:WayPoint countryCode="" wayPointType="VIA" manoeuvreIdx="11" segmentIdx="283" nodeIdx="331" polyIdx="428" iuCode="49" accDist="33638" accTime="3232">
<ns3:locationCoord>
<ns1:point y="49.787068238" x="9.9420152269"/>
<ns3:matchCoord>
<ns1:point y="49.7870345" x="9.9421436108"/>
</ns3:matchCoord>
</ns3:WayPoint>
<ns3:WayPoint countryCode="" wayPointType="VIA" manoeuvreIdx="13" segmentIdx="589" nodeIdx="702" polyIdx="904" iuCode="49" accDist="74696" accTime="7747">
<ns3:locationCoord>
<ns1:point y="49.490882383" x="9.7799452642"/>
<ns3:matchCoord>
<ns1:point y="49.49096722" x="9.7799338084"/>
</ns3:matchCoord>
</ns3:WayPoint>
<ns3:WayPoint countryCode="" wayPointType="DEST" manoeuvreIdx="26" segmentIdx="1041" nodeIdx="1267" polyIdx="1604" iuCode="49" accDist="144388" accTime="13822">
<ns3:locationCoord>
<ns3:matchCoord>
</ns3:matchCoord>
</ns3:WayPoint>
</ns3:wrappedStations>
<ns3:wrappedTexts xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns3:route>
<ns3:recreationPeriods weeklyRestPeriod="0" dailyRestPeriod="0" breakPeriod="0"/>
<ns3:wrappedTourEvents>
<ns3:TourEvent segmentIndex="0" period="0" startTime="2018-03-27T14:22:07Z" tourPointIndex="0">
<ns3:wrappedDescriptions>
<ns0:String>SERVICE</ns0:String>
<ns0:String>IS_IN_SERVICE_INTERVAL</ns0:String>
</ns3:wrappedDescriptions>
<ns3:wrappedViolations/>
</ns3:TourEvent>
<ns3:TourEvent segmentIndex="0" period="3272" startTime="2018-03-27T14:22:07Z" tourPointIndex="-1">
<ns0:String>DRIVING</ns0:String>
</ns3:TourEvent>
<ns3:TourEvent segmentIndex="283" period="1000" startTime="2018-03-27T15:16:39Z" tourPointIndex="1">
</ns3:TourEvent>
<ns3:TourEvent segmentIndex="285" period="3515" startTime="2018-03-27T15:33:19Z" tourPointIndex="-1">
</ns3:TourEvent>
<ns3:TourEvent segmentIndex="589" period="1600" startTime="2018-03-27T16:31:54Z" tourPointIndex="2">
</ns3:TourEvent>
<ns3:TourEvent segmentIndex="595" period="4515" startTime="2018-03-27T16:58:34Z" tourPointIndex="-1">
</ns3:TourEvent>
<ns3:TourEvent segmentIndex="1041" period="200" startTime="2018-03-27T18:13:49Z" tourPointIndex="3">
</ns3:TourEvent>
</ns3:wrappedTourEvents>
<ns3:wrappedTourPointResults>
<ns3:TourPointResult stationIndex="0" genuineWaitingPeriod="0" departureTime="2018-03-27T14:22:07Z" endServiceTime="2018-03-27T14:22:07Z" startServiceTime="2018-03-27T14:22:07Z" arrivalTime="2018-03-27T14:22:07Z">
<ns3:recreationPeriodsAtTourPoint weeklyRestPeriod="0" dailyRestPeriod="0" breakPeriod="0"/>
<ns3:recreationPeriodsOnRoad weeklyRestPeriod="0" dailyRestPeriod="0" breakPeriod="0"/>
</ns3:TourPointResult>
<ns3:TourPointResult stationIndex="1" genuineWaitingPeriod="0" departureTime="2018-03-27T15:33:19Z" endServiceTime="2018-03-27T15:33:19Z" startServiceTime="2018-03-27T15:16:39Z" arrivalTime="2018-03-27T15:16:39Z">
<ns3:TourPointResult stationIndex="2" genuineWaitingPeriod="0" departureTime="2018-03-27T16:58:34Z" endServiceTime="2018-03-27T16:58:34Z" startServiceTime="2018-03-27T16:31:54Z" arrivalTime="2018-03-27T16:31:54Z">
<ns3:TourPointResult stationIndex="3" genuineWaitingPeriod="0" departureTime="2018-03-27T18:17:09Z" endServiceTime="2018-03-27T18:17:09Z" startServiceTime="2018-03-27T18:13:49Z" arrivalTime="2018-03-27T18:13:49Z">
</ns3:wrappedTourPointResults>
</ns4:result>
</ns4:calculateAdvancedTourResponse>
</soap:Body>
</soap:Envelope>
