is it possible to provide a sample profile snippet that activates the usage of the historical speed patterns?
Uli
Activation of the historical speed patterns
michel_wsc
Re: Activation of the historical speed patterns
Sure - try this one:
It uses FeatureLayers (PTV_SpeedPatterns for historical car data, PTV_TruckSpeedPatterns for historical truck data) and in combination with the RoutingOption.START_TIME (not possible to be preconfigured) it will ensure that the driving times and distances reflect the historical daytime conditions.
Be aware that this fragment only set's the values which are relevant for your usecase. Any other property such as vehicles dimensions are not part of the sample.
<Profile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http:///xroute/schema/XRouteProfile.xsd">
<GlobalSettings enableTimeDependency="true"/>
<Themes>
<Theme id="PTV_SpeedPatterns" enabled="true"/>
</Themes>
</FeatureLayer>
<Course>
<AdditionalDataRules enabled="true"/>
<DynamicRouting limitDynamicSpeedToStaticSpeed="false"/>
</Course>
</Routing>
</Profile>Bernd Welter
michel_wsc
...thanks a lot. It's working fine!
