Calc smartest route
Posted: Mon Feb 19, 2018 8:33 am
I am quite new to PTV-xServer and neither the samples or documentation could help me, so I am asking here.
Our problem is, that we have to calculate the "smartest" route: The start and target points are fix (both are the same actually), the other waypoints should be in the fastest order.
I have to work with the Java classes of PTV and need a function which calculates the best order.
My current conclusion:
- XTour is a bit too much for this, we have no detailed tour data, just the waypoints.
- XDima calculates a big a matrix, but we don't need all this information.
- XRoute has calculateExtendedRoute, calculateRoute, polygons, toll etc. and it's working fine, but we need the best order of the waypoints which is no feature of those functions.
There is a calculateTour function, but it doesn't calculate the smartest order, does it? Sadly it doesn't work for me: "conflict tour calculation - both start and destination waypoints need to be tour points" Currently I use it exactly like calculateExtendedRoute/calculateRoute, but I can't find a proper documentation or example and I am not even sure if it is able to calculate the best order.
Can you give me a hint what to do?
Thanks in advance!
Best Regards,
Fabian
Thanks in advance!
Best Regards,
Fabian
