MaxTourEarlinessPeriod & MaxStopEarlinessPeriod
log-konz
Post by log-konz »
Hello PTV-Team,
in the file "TourOpt.ini" I can globally set the parameters MaxTourEarlinessPeriod and MaxStopEarlinessPeriod.
These two parameters are used for each request.
The question is if it is also possible to set the parameters for each request individual?
Or is it possible that I can overwrite the parameter for each request?
Thank you for your help. :D
Re: MaxTourEarlinessPeriod & MaxStopEarlinessPeriod
Hello Daniel,
the parameter you refer to is not available as an API parameter. This means that you can only set it in the TourOpt.INI.
Maybe we can give you some specific advice if we know more about the usecase. Therefore I recommend to get in touch with your local consultant.
