				Translate traffic information
				Posted: Thu Jan 04, 2018 9:22 am
				by alex.mihov
				Hello together,
How can we translate the messages about traffic, closed roads etc into different languages?
Also what languages are supported?
For now we only have the german ones:
18 Richtung Delémont/Reinach-Nord bei Muttenz Veränderte Verkehrsführung im Baustellenbereich
Thanks in advance
				Re: Translate traffic information
				Posted: Thu Jan 04, 2018 9:28 am
				Hello together,
the language used in the traffic info loader descriptions is configured in a file named “traffic-geodatasource.xml” (left side of the screenshot).
Check the screenshot.
-  LEFT: configuration of the traffic info loader plugin. It consumes the events incl. the messages  and stores the info in the database table
 CENTER: the database table (in my system I used MS SQL Server but you can also use other RDBMS)
 RIGHT: the geodatasource configuration file which is responsible for the consumption of the geometry (display via xmap) and exception_path (detour via xroute)
The traffic info loader is based on a two step architecture:
- The Traffic Info Loader plugin consumes the traffic events and messages via internet and stores them into a database
 My screenshot shows the table on the right. The table contains several description columns such as
- C_DESCRIPTION_DE which contains the German text message
- C_DESCRIPTION_EN which contains the English version
- … and so on
 The configuration of the Traffic Info Loader is part of the file TrafficInfoLoader.properties
- The second component is the reading access of xMap and xRoute which is based on the GEODATASOURCE layer.
 A geodatasource layer shows database content (not only traffic messages but also POIs or areas) and determines
 the relevant table columns based on a file such as traffic-geodatasource.xml (left side of the screenshot).
 The default text message refers to C_DESCRIPTION_DE. If you want to use English just reconfigure line14
 to use C_ DESCRIPTION_EN.
- One sidenote: if you want to switch between several translations via API this is also possible but requires
 several configuration files.
- Please be aware that the state-of-the-art approach of Traffic Message consumption is the feature layer PTV_TrafficIncidents (replaces geodatasource) which is updated via the Content Update Service (replaces traffic info loader).
				Posted: Thu Jan 04, 2018 9:41 am
				by alex.mihov
				Hi Bernd, thanks for the elaboration.
In our case, we are using PTV as a Service and consume the service as follows:
this.traffic = new L.PtvLayer.TrafficInformation('https://xmap-eu-n.cloud.ptvgroup.com', {
      zIndex: 1,
      token: 'xxxxxxxxxxxxxxxx'
We looked it up here:
https://github.com/ptv-logistics/Leafle ... er.js#L309
Can you explain to us how to get the different traffic information languages this way?
All the best!
				Posted: Mon Jan 08, 2018 6:46 pm
				by Oliver Heilig
				Hello Alex,
i must say this is not that simple out-of-the-box. It requires a layer-configuration which returns multiple language fields. This is not supported by the default configration of the TrafficInformation layer. However, there's an alternative "map&guide-internet" TrafficInfoLayer that returns the description for multiple languages. Suported are '
DE', '
EN', '
FR', '
NL' and '
IT'. I've added a layer class
 L.PtvLayer.TrafficInformation.Mgi to the GitHub project:
https://github.com/ptv-logistics/Leafle ... #L341-L377
This supports a 'language' option (see code below). I've updated the sample of the project to display the english description
http://ptv-logistics.github.io/Leaflet.PtvLayer/. We'll check if we can add the multi-language support to the default-configuration.
// add traffic information - use the map&guide-internet configuration
var traffic = new L.PtvLayer.TrafficInformation.Mgi(xMapUrl, {
   zIndex: 1,
   attribution: xMapAttribution,
   language: 'EN',
   token: token
}).addTo(map);
Oli
				Posted: Wed Jan 17, 2018 1:37 pm
				by alex.mihov
				Hi Oli,
I just today saw that you had answered... We have implemented the new solution, thanks
The one question that we have no is, is it possible to configure the units for the other languages?
For example in English we get the distances in yards instead of KM which would be a nice addition.
All the best,
Alex
				Posted: Wed Jan 17, 2018 2:19 pm
				Hello ALex,
unfortunately the units are metric only.
				Posted: Thu Jan 18, 2018 1:15 pm
				by alex.mihov
When we switch to English, the units are imperial, i.e. the distance is shown in yards:
Route de Veyrier bei Carouge 487 yards of traffic
What would be nice to have is a possibility to get everything metric or everything imperial; but i guess there is no way to set that?
				Posted: Thu Jan 18, 2018 1:56 pm
				Hello Alex,
those texts are probably retrieved by the provider and forwarded 1:1, so you might be able to change the language but you still depend on what the provider wrote into the text.
For any businesscase I assume that you want to get the properties of a route in imperial units, such as segment length or route lenght. Afaik those values are metric only.
