Forcing an error message in case of missing profile
daxbin
Post by daxbin »
I'm using xRoute via Java WS API.
Years ago I got the following exception, if I used a wrong (e.g. misspelled) profile name:
com.ptvag.jabba.core.exception.UnexpectedException:
requested profile does not exist: xxxxx
Now I don't get an error but a regular result because xRoute falls back to a default profile silently
(it only logs a warning "Requested profile xxxxx.xml which does not exist, using default.xml instead.")
How can I get the xRoute to generate an error message again?
I can't find the corresponding entry in e.g. xroute.properties.
Best regards, Birk
Re: Forcing an error message in case of missing profile
Hello Dirk,
check xserver.properites... as the desired behaviour is a FRAMEWORK topic it is a generic key:
# fail if a non-existing profile is requested
#failOnIllegalProfile=false
failOnIllegalProfile=true
daxbin
Post by daxbin »
thanks a lot, that was exactly what I was looking for.
Birk
BTW, Your red Xmas coat looks great!
