TransportPoint Priority
Posted: Tue Oct 31, 2017 9:41 am
by puissancei
is it possible to set priority to TransportPoint ?
I need to prioritize the TransportPoint between them.
Some place have to be deliver before other.
I already use the product priority whose purpose is different.
Thank you
Re: TransportPoint Priority
Posted: Tue Oct 31, 2017 10:00 am
by Joost
I believe what you are looking for is the toursection attribute. From the documentation:
Position of the transport point in a tour (0 <= tourSection <= 1000). Within a tour the tourSection values != 0 of the transport points will be sorted ascending so that it is possible to pre-order the transport points. Transport points with tourSection 0 will be placed anywhere. TourSection 1 will be the first stop within a tour, and 1000 will be the last stop. There will be not more than one transport points within a tour with tourSection 1 or 1000, respectively.
General remark: with in xTour priority does nothing with the order points are inserted into a tour. Priority only raises the chance an order will be planned in, it has no effect where in the plan is will end up.
Posted: Fri Nov 03, 2017 3:44 pm
by puissancei
When I use tourSection with transportAB I have the following message.
Could not plan basic tours (Reason: Could not set partner relation). Engine error: Invalid partner stop tour position (code: -1063) in transport order 2000.
How I have to fill tourSection ? How it works exactly ?
Thank you
Posted: Fri Nov 03, 2017 4:13 pm
by Joost
In case of an AB order, transportpointA.toursection should be smaller or equal to transportpointB.toursection. I'm not sure how a value of 0 is allowed for only one of them since 0 is special value for anywhere. I'll check this further.
Posted: Fri Nov 03, 2017 4:27 pm
by Joost
0 values are allowed and do not violate the a.toursection <= b.toursection rule. B.toursection should be greater then 1 since 1 means "has to be at the begin of the tour" which does not leave room for A to be inserted before.
Examples:
A.toursection = 0, B.toursection = 0 => valid
A.toursection = 0, B.toursection = 5 => valid
A.toursection = 5, B.toursection = 0 => valid
A.toursection = 5, B.toursection = 5 => valid
A.toursection = 8, B.toursection = 5 => invalid
A.toursection = 0, B.toursection = 1 => invalid
Posted: Mon Nov 06, 2017 7:39 am
by puissancei
very clear.
Thank you
Posted: Thu Nov 23, 2017 1:22 pm
Hello Michele,Joost,
@Joost: thanks for the detailed comments.
@Michele: be aware that the tour section handling as described by Joost is easy to use within a planning of a single tour.
But: it could get challenging if you want to dispatch various AB-Orders over a set of vehicles and you still want to ensure some kind of internal sequences. Maybe it is a good idea to get in touch with Clement to check this usecase in detail.
Of course Joosts hints are great to know but sometimes a full picture of the "requirement" gives us important info for an optimal paramneter set.
By the way: here's a post about priorities
http://xserver.ptvgroup.com/forum/viewt ... ?f=6&t=719
