Dependency between matrix size and memory size
Posted: Mon Jun 19, 2017 10:34 am
by Karol.Korol
in PTV xServer Version 1.24 documentation we can read:
"The matrix should not be larger than 750x750 waypoints, otherwise PTV xRoute Server might run out of memory."
I like to know what is the dependency between matrix size and memory.
E.g.
how much memory should i have, to calculate matrix 2000x2000 waypoints or larger.
Is there a formula that will allow me to calculate memory size by myself?
Re: Dependency between matrix size and memory size
Posted: Thu Jun 22, 2017 7:49 am
Hello Karol,
at least within xDima and xTour the size of a Dima can be much bigger (no problem to computate 10'000 in square with high performance routing). I forwarded this question to DEV for a feedback,
Maybe you should consider to use the xDima - depending on your usecase.
Posted: Tue Jul 04, 2017 11:23 am
Hello Karol,
I received an answer from DEV:
Let's compare a task of "700x700 routings". The temporary backend complexity with xTour, xDima and xRoute is probably almost on the same (eeeeeasy) level. But:
- xRouteServer : if you request that size the response would contain about 500.000 XML nodes. The webserver will not be able to handle that document complexity and size.
- xDimaServer / xTourServer: in these cases the dima itself isn't transferred to the client - just some data (plan, tours, ...) that are based on the distances. Of course a single xDima.getDistPeriod with the 500.000 would also crash but here you could slice the load easily.
OK with that explanation?
Posted: Mon Jul 17, 2017 12:24 pm
by Karol.Korol
Thank you for your answer.
But how does it look when I use JSON data model? During the one of webinar ("PTV xServer - functional overview routing topics") you showed the calculation of matrix 2kx2k. You used xRouteServer or xDimaServer / xTourServer?
Posted: Mon Jul 17, 2017 1:00 pm
Hello Karol,
for the demo of HighPerformanceRouting I'm always using the xTour testclient with all planing functions being disabled.
I think the JSON interface would cause the same complexity. I doubt this is going to work.
