xRouteServer feature layer installation on Linux
Posted: Tue May 23, 2017 2:18 pm
Hello Guys,
I would like to use PTV xRouteServer with feature layer (with TruckAttributes) on linux but unfortunatelly I have some issues. When "featurelayer" folder is presented under the map folder (EuroPremium.geo) xRoute server could not be started. If I remove the "featurelayer" folder the server can be started but obviously feature layer could not be used in route planning.
Here are my environment's parameters:
xRouteServer version: 1.24.0.0 x64 gcc4
JVM: Java SE Runtime Environment1.8.0_121-b13 (amd64)
OS: Ubuntu Server 16.04 LTS
Map: PTV_Europe_City_Map_Premium_2017_1H_8
Here are the xRoute error logs when "featurelayer" folder is presented:
Could you please help use to figure out why we get the above errors?
Thank you in advance
BR
Daniel
Running PTV xRoute Server 1.24.0.0...
STATUS | --> Wrapper Started as Console
STATUS | Java Service Wrapper Standard Edition 64-bit 3.5.25
STATUS | Copyright (C) 1999-2014 Tanuki Software, Ltd. All Rights Reserved.
STATUS | http://wrapper.tanukisoftware.com
STATUS | Licensed to PTV Group for PTV xServer
STATUS |
STATUS | Launching a JVM...
INFO | WrapperManager: Initializing...
INFO | [com.ptvag.xserver.utils.startuptasks.StartupTasksExecutor] Looking for startup tasks in directory /opt/xroute/work/startup-tasks
INFO | [com.ptvag.xserver.utils.startuptasks.StartupTasksExecutor] Startup tasks directory /opt/xroute/work/startup-tasks does not exist - continuing with server startup ...
INFO | May 23, 2017 1:36:07 PM org.apache.coyote.AbstractProtocol init
INFO | INFO: Initializing ProtocolHandler ["http-bio-50030"]
INFO | May 23, 2017 1:36:07 PM org.apache.catalina.startup.Catalina load
INFO | INFO: Initialization processed in 563 ms
INFO | May 23, 2017 1:36:07 PM org.apache.catalina.core.StandardService startInternal
INFO | INFO: Starting service PtvXServerService
INFO | May 23, 2017 1:36:07 PM org.apache.catalina.core.StandardEngine startInternal
INFO | INFO: Starting Servlet Engine: Apache Tomcat/7.0.57
INFO | May 23, 2017 1:36:07 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO | INFO: Deploying configuration descriptor /opt/xroute/conf/Catalina/localhost/ROOT.xml
INFO | May 23, 2017 1:36:08 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO | INFO: Deployment of configuration descriptor /opt/xroute/conf/Catalina/localhost/ROOT.xml has finished in 978 ms
INFO | May 23, 2017 1:36:08 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO | INFO: Deploying web application directory /opt/xroute/webapps/derby
INFO | May 23, 2017 1:36:10 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO | INFO: Deployment of web application directory /opt/xroute/webapps/derby has finished in 2,039 ms
INFO | INFO: Deploying web application directory /opt/xroute/webapps/xroute
INFO | May 23, 2017 1:36:13 PM org.apache.catalina.core.ApplicationContext log
INFO | INFO: org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: loaded (conf ok)
INFO | log4j:WARN No appenders could be found for logger (org.apache.cxf.common.logging.LogUtils).
INFO | log4j:WARN Please initialize the log4j system properly.
INFO | XRoute server starting...
INFO | ... initializing server environment ...
INFO | 2017-05-23 13:36:15,617;WARN;com.ptvgroup.xserver.framework.XServer1Dispatcher;queueing timeout <= 0 (-1ms) - using 60 secs instead
INFO | 2017-05-23 13:36:15,644;INFO;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Starting module instance m0001 in external process...
INFO | 2017-05-23 13:36:15,644;INFO;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Starting module instance m0002 in external process...
INFO | 2017-05-23 13:36:16,877;INFO;com.ptvag.xserver.module.xroute.m0001;<no-request>;-;-;-;Created default directory for ShMemPath /opt/xroute/dyn/shm/
INFO | 2017-05-23 13:36:16,878;INFO;com.ptvag.xserver.module.xroute.m0001;<no-request>;-;-;-;Created default directory for CurrREDBPath /opt/xroute/dyn/layer/
INFO | 2017-05-23 13:36:34,353;ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Module instance m0001 shutting down with exit code 134.
INFO | 2017-05-23 13:36:34,682;ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Error on starting module instance m0001: java.lang.RuntimeException: Module instance has terminated unexpectedly
INFO | java.lang.RuntimeException: Module instance has terminated unexpectedly
INFO | at com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper.waitForStartup(ModuleInstanceProcessWrapper.java:597)
INFO | at com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper.startProcess(ModuleInstanceProcessWrapper.java:558)
INFO | at com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper.doStartSeparateProcess(ModuleInstanceProcessWrapper.java:415)
INFO | at com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper.doStart(ModuleInstanceProcessWrapper.java:388)
INFO | at com.google.common.util.concurrent.AbstractService.start(AbstractService.java:171)
INFO | at com.google.common.util.concurrent.AbstractService.startAndWait(AbstractService.java:221)
INFO | at com.ptvgroup.xserver.framework.ModuleAgent$ModuleRunner.startProcessor(ModuleAgent.java:371)
INFO | at com.ptvgroup.xserver.framework.ModuleAgent$ModuleRunner.run(ModuleAgent.java:243)
INFO | at java.lang.Thread.run(Thread.java:745)
INFO | 2017-05-23 13:36:34,686;ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Error during starting module instance m0001: ModuleInstanceStartupException, exitCode = 134
INFO | ModuleInstanceStartupException, exitCode = 134
INFO | at com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper.startProcess(ModuleInstanceProcessWrapper.java:572)
INFO | 2017-05-23 13:36:34,758;ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Module instance m0002 shutting down with exit code 134.
INFO | 2017-05-23 13:36:35,701;ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Error on starting module instance m0002: java.lang.RuntimeException: Module instance has terminated unexpectedly
INFO | 2017-05-23 13:36:35,701;ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;xroute: Error during starting module instance m0002: ModuleInstanceStartupException, exitCode = 134
INFO | System.exit(50)
INFO | May 23, 2017 1:36:36 PM org.apache.catalina.core.StandardContext loadOnStartup
INFO | SEVERE: Servlet /xroute threw load() exception
INFO | ModuleInstanceStartupException, exitCode = 50
INFO | at com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper.startProcess(ModuleInstanceProcessWrapper.java:580)
INFO |
INFO | Derby database stopped
STATUS | <-- Wrapper Stopped
BR
Daniel
