Good to know: PROFILES
Posted: Tue May 23, 2017 8:00 am
another important hint due to current issues: I'd just like to draw your attention to the term PROFILE in the context of xServers. The word is used in different meanings and so the following overview could give you a better understanding how not to mix it up:
- RequestProfile: this is a generic framework, optional parameter that occurs in each x-module. It is used to request a set of server side parameters,e.g. the profile file is named xlocate-schabernack.properties and it's content is requested like this:
<ns4:CallerContext_4> <ns6:wrappedProperties> <ns6:CallerContextProperty value="schabernack" key="Profile"/> </ns6:wrappedProperties> </ns4:CallerContext_4> - DimaProfile (routing): this s the logical name of a set of ROUTING parameters that are combined in a server side file.
This mechanism is used within xTour, xDima, xTerritory and xCluster. If the profileName==dimaCar the server looks for the file dimaCar.xml and so on.
<wrappedDistanceMatrixCalculation> <DistanceMatrixCalculation xsi:type="DistanceMatrixByRoad" profileName="dimaCar" deleteAfterUsage="true" deleteBeforeUsage="true" dimaId="1"/> <DistanceMatrixCalculation xsi:type="DistanceMatrixByRoad" profileName="dimaTruck" deleteAfterUsage="true" deleteBeforeUsage="true" dimaId="2"/> </wrappedDistanceMatrixCalculation> - RenderProfile (mapping): a render profile describes a large number of parameters of a map rendering process such as colors of objects (e.g. streets, signs), font characteristics (size and additional behaviour), what info is displayed at what zoom level (truck attributes up to max scale of...). It is possible to create a customized render profile which is then referenced via a request profile (e.g. the request profile xmap-silkysand.properties refers to the rendering profile silkysand.ini): just some lines of a larger set:
[config.town.symbols]
; Sets the kind of town symbol.
; 0 for rectangle
; 1 for circle
; 2 for cross
; 3 for ADAC atlas
; 4 for circles with and without a inner black circle and a rectangle (depending
; on the category).
symbolkind=4
; Fill color of town symbols.
symbolcolor=16777215
; Frame color of town symbols.
symbolframecolor=0 - EffectiveProfile (routing): the effective profile is the XML formatted routing profile that is assembled on serverside after applying the routing parameters specified within the hierarchy of
- RoutingOptions
- XML Snippet
- RequestProfile
- Server default values
Gathering the effective profile is quite helpful if you want to reproduce routings on a remote server if you don't have the opportunity to manipulate server files.# enables logging of the effective profile being used (at DEBUG level, adapt server-logging.properties and module-logging.properties)
# for debugging purposes only, do not enable permanently in a productive environment
# since 1.17
#log.effectiveProfile=false
log.effectiveProfile=true
- A single xTour request can handle more than one DImaProfiles.
