New high performance profile available: hpr-car
since last week the test cloud https://xtour-eu-n-test.cloud.ptvgroup.com provides an additional high performance routing profile named hpr-car. It is intended to server usecases such as service technicians, fieldforce or any other fleet / vehicle that is based on cars instead of trucks.
The new searchgraph profile is based on the regular car profile and accelerates the DistanceMatrixByRoad. To activate the profile you have to use the DistanceMatrixByRoad.dimaProfile as in the following XML fragment:
<ns4:wrappedDistanceMatrixCalculation>
<ns4:DistanceMatrixCalculation
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns4:DistanceMatrixByRoad"
 deleteBeforeUsage="true" deleteAfterUsage="true"
 referenceTime="1970-01-01T01:00:00+01:00" dimaId="497"
 profileName="hpr-car"/>
</ns4:wrappedDistanceMatrixCalculation>
Attention:
  • Using the request profile is not sufficient! As there is no corresponding request profile you need to set the dimaProfile parameter.
  • deleteBefore/deleteAfter can be used as with other non HPR profiles
  • This profile isn't available on production so far. It will follow soon.
Feedback is welcome,
IsH-PTVAG
Re: New high performance profile available: hpr-car
Post by IsH-PTVAG »
the high performance profile hpr-car will be available in the near future.
It will be installed on the Europe production system with the next scheduled update end of July.
Together with the map and PTV xServer update the new hpr profile will be provided for productive use.
As usual the update will be announced 4 weeks in advance.
Kind regards,
Isabel Honikel
Isabel Honikel
Product Manager
PTV GERMANY
