Sample problem using Truck Attributes with ajax maps
nemec
Post by nemec »
i have found this sample , that i need for my application
http://127.0.0.1:50010/ajaxmaps/tutoria ... e%20Layers
i have tried so start it on our local server.
no success - Internal Server Error in console and failed so load image in the qx-console
Re: Sample problem using Truck Attributes with ajax maps
did you already reconfigure to use your dedicated map?
If this is the case: did you install the additional FeatureLayer data?
Further hint:
Your sample runs fine on my local machine. But obviously the reference time is set to a wrong date: requesting 2014 data won't display traffic based on 2017 data...
nemec
Post by nemec »
it runs now and it was not the problem, that the layer wasn't installed.
it was solved the last days of may, i forgot to mention it here, sorry.
so what caused the issue? Could the community benefit from this info?
