xTour decision for depot of order
Posted: Fri Apr 28, 2017 5:48 am
by Lauterfeld
in xTour we can let xTour chose the 'best' depot of an order. If we have an order and 2 or more depots - what is the rule for xTour to chose the best depot? Is it the routing distance from depot to order? Or is it the driving duration? Or a combination of that?
Volker.
Re: xTour decision for depot of order
Posted: Fri Apr 28, 2017 9:30 am
Hello Volker,
Here's the response from Alex:
There is some kind of a default vehicle configured in the TourOpt.INI. This vehicle is applied for each depot with a linear combination based on driving time, travel time and distance. This is used for an initial assignment.
Within the MergeSavings algorithm the assignment may change.
Is this info sufficient?
PS:
In TourOpt gibt es sowas wie ein Standardfahrzeug. Damit wird für jedes Depot geprüft, wie teuer ein Depot kommt. Dabei wird wie üblich eine Linearkombination aus Fahrzeit, Reisezeit und Distanz verwendet.
Initial wird das beste Depot zugeordnet. Beim MergeSavings kann diese Zuordnung während des Verfahrens wechseln.
Posted: Fri Apr 28, 2017 11:22 am
by Lauterfeld
Tanks all!
