planBasicTours not accepting GPScoordinates in OG_GEODECIMAL
Posted: Thu Apr 27, 2017 7:47 am
Problem:
xtour api accepting GPS coordinates in PTV_MERCATOR(e.g 16777907.815,-4080923.1128)
but not accepting GPS coordinates in OG_GEODECIMAL (e.g -34.421025,150.887075)
although i am setting in callerContext
"key": "coordFormat", "value": "OG_GEODECIMAL"
Steps to reproduce:
PTV xServer Raw Request Runner
https://xlocate-au-n-test.cloud.ptvgrou ... quest.html
see attached payload1.json with GPS coordinates in PTV_MERCATOR
see payload2.json with exactly same as payload1.json but GPS coordinates in OG_GEODECIMAL
paste payload1.josn & payload2.json in request runner
payload1.json works fine as it have GPS coordinates in PTV_MERCATOR but
payload2.json throwing
error:
i have also tried to shuffle x & y in logistic point. but it didn't worked in either way
as an workaround
i'm bound to use xlocate -> findAddresses to convert GPS coordinates
from OG_GEODECIMAL to PTV_MERCATOR before using xtour. (i have option of javascript only)
causing overhead.
if planBasicTours cannot accept GPS coordinates in OG_GEODECIMAL
is there better quick (in term of performance) for GPS conversion?
Thanks in Advance
Steps to reproduce:
error:
"errorMessage": "Could not plan basic tours (Reason: Could not calculate distance table for dima with ID 1). Engine error: Locations not linked (code: -1023).",
"errorKey": "10003",
"exceptionType": "com.ptvag.xserver.xtour.XTourException"
}as an workaround
causing overhead.
Thanks in Advance
