startPlanSequence - SoapException - DimaId
peter.detzner
Post by peter.detzner »
Hi!
I am sending a startPlanSequence-Request to the xServer where I am receiving the following error message:
An exception of type 'System.Web.Services.Protocols.SoapException' occurred in System.Web.Services.dll but was not handled in user code
Additional information: Could not plan sequence (Reason: Could not calculate distance table for dima with ID 1). Engine error: Locations not linked (code: -1023).
About my setup:
- 7 TransportOrderSteps (Ids: 1-7)
- 1 Vehicle
seqVehicle.depotIdEnd = 10;
seqVehicle.depotIdStart = 10;
seqVehicle.dimaId = 1;
seqVehicle.dimaIdSpecified = true;
- 1 Depot
basisDepot.id = 10;
Here some futher lines of code:
SequencingParams sParams = new SequencingParams()
    wrappedDistanceMatrixCalculation = new[] {new DistanceMatrixByRoad
        dimaId = 1,
        deleteBeforeUsage = true,
        deleteAfterUsage = true,
        profileName = "dimaTruck",
    availableMachineTime = 15,
    availableMachineTimeSpecified = true
What am I missing resp doing wrong?!
Re: startPlanSequence - SoapException - DimaId
Hello Peter,
probably the request itself is ok but there might be a problem with the coordinates of the locations.
Locations not linked means that one or more involved coordinates are located too far away from the street network configured in the xtour.properties maps.path.
Please ensure whether the path is configured to a map that fits the cordinates.
Otherwise please capture the request and provide it to your technical contact at PTV. (The deeper analysis of the request isn't of public interest - but maybe the result is worth being shared).
Furthermore I recommend to use planBasicTours instead of planSequence because it is more powerful and flexible.
Best regards from Germany,
