html alignment
Posted: Fri Mar 31, 2017 10:19 am
Not sure if this is a bug or im missing something obvious
Currently when adding an HTML element to the map the alignment appears to be failing, so even though i set the alignment to be MID VERT and MID HORIZ it aligns to 'TOP LEFT'.
You can clearly see this in the attached image. The drawn circle at the same XY is correct but the HTML element added to the same XY is aligning to the top left of the icon
sample code:
Any ideas?
sample code:
var html = new vector.HTML();
html.set({x:con.x,y:con.y});
html.setAlignment(VectorLayerClass.ALIGN_MID_VERT + VectorLayerClass.ALIGN_MID_HORIZ);
html.setHtml('<img id="img27448381L2D" src="./romapicons/cir1/cir10DFCA4.png" />');
html.setTopLevel(true);
vectorLayer.addElement(html);
