				Calculating Route with different result routes?!
				Posted: Thu Mar 30, 2017 5:23 am
				by peter.detzner
I'd like to know if there is an option to send one request and to receivce different result-routes based upon different features (e.g. distance, time, emission, toll)!?
Peter
				Re: Calculating Route with different result routes?!
				Posted: Thu Mar 30, 2017 6:50 am
				Hello Peter,
you mean a single waypoint list in combination with a set of different parameter sets?
No, that's not possible.
We offer some bulk operations that can be used as shortcuts:
- calculateBulkRouteInfo
(waypoints:WaypointDesc[][],options:RoutingOption[],exceptionPaths:ExceptionPath[]):BulkRouteInfo
set of waypoint lists, all routes will apply same options
- calculateMatrixInfo(startwaypoints:WaypointDesc[],destwaypoints:WaypointDesc[],options:RoutingOption[],matrixOption:MatrixOptions):MatrixInfo
set of starts multiplied with set of destinations, all routes will apply same options
So the one you asked for is missing
 But with a server that has several backend modules you will be able to compute the given tasks in parallel.
What is the exact goal or challenge you want to deal with?
				Posted: Thu Mar 30, 2017 8:09 am
				by peter.detzner
				I'd like to show the user different routes types (e.g. optimized in distance, time, fastest, lowest emission, toll cost), just for information purpose...
				Posted: Thu Mar 30, 2017 8:50 am
				In this case you have to call calculate
[..]Route once per different parameter set to get the required output.
-  calculateRouteInfo : just driving time and distance
-  calculateRoute : same as calculateRouteInfo  PLUS polygon, segment info, emissions, manoeuvres...
-  calculateExtendedRoute : same as calculateRoute PLUS toll infos...
