High Performance Routing with xRouteServer
daxbin
Post by daxbin »
I'd like to test high performance routing (HPR).
Therefore I did a setup of the two (built in) profiles carfast and carslow for
  • xdima-x64-1.22.0.3 and
  • xroute-x64-1.22.0.0 servers.
For carfast I created a high performance routing network file with the routingnetworkgenerator tool.
Then I have calculated a 625×625 dima
  • once with xDima.calculateDistanceTable and
  • once with xRoute.calculateMatrixInfo
which both should be benefit from available HPR network files as one can read in the docs.
More accurately I used the asynchronous way of invoking the calculation (e.g. startCalculateMatrixInfo).
I've got the following results:
xServer  Profile  HPR  Size-X  Size-Y  --Time
xDima    carfast   ×     625     625    1,8 s
xDima    carslow   –     625     625   39,0 s
xRoute   carfast   ×     625     625   43,2 s
xRoute   carslow   –     625     625   42,2 s
While xDima shows a significant difference in the calculation time, this is not visible when using xRoute.
I already checked:
  • The maps.highPerformanceRoutingNetworkDir is set both in xdima.properties and xroute.properties.
  • The routing is not dynamic in the sense that no RoutingOptions or VehicleOptions are set neither for the whole route or for single waypoints nor a ProfileXMLSnippet is set in the CallerContext.
  • In the logs there was nothing special.
  • The license.ptv has both
    • xroute.highPerformanceRouting=true and
    • xdima.highPerformanceRouting=true.
Is there still something I could check, so that HPR also works with xRouteServer?
Birk
daxbin
Re: High Performance Routing with xRouteServer
Post by daxbin »
After raising log level from INFO to DEBUG (like mentioned in Troubleshooting section of the docs) I found
2017-03-23 19:09:49,891;DEBUG;com.ptvag.xserver.module.xroute.m0001;ad475935-6c52-495d-aac9-942cb144ba39;;;;High-performance routing cannot be used due to incompatible routingOptions, vehicleOptions, or waypoints. Use conventional routing instead.
in the log which I have to further investigate in.
daxbin
Post by daxbin »
Next step was to investigate the (simplified to a 2×2 dima) request
  <soap:Body>
    <ns4:calculateMatrixInfo xmlns:ns4="http://types.xroute.xserver.ptvag.com">
      <ns4:ArrayOfWaypointDesc_1>
        <ns3:WaypointDesc xmlns:ns3="http://xroute.xserver.ptvag.com" linkType="NEXT_SEGMENT" fuzzyRadius="0">
          <ns3:wrappedCoords>
            <ns1:Point xmlns:ns1="http://common.xserver.ptvag.com">
              <ns1:point x="1350000.0000000002" y="5100000.000000001" z="0.0" />
            </ns1:Point>
          </ns3:wrappedCoords>
          <ns3:wrappedSegmentID xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
        </ns3:WaypointDesc>
          <ns3:wrappedCoords>
              <ns1:point x="1350000.0000000002" y="5100250.000000001" z="0.0" />
            </ns1:Point>
        </ns3:WaypointDesc>
          <ns3:wrappedCoords>
              <ns1:point x="1350250.0000000002" y="5100000.000000001" z="0.0" />
            </ns1:Point>
        </ns3:WaypointDesc>
          <ns3:wrappedCoords>
              <ns1:point x="1350250.0000000002" y="5100250.000000001" z="0.0" />
            </ns1:Point>
        </ns3:WaypointDesc>
      </ns4:ArrayOfWaypointDesc_1>
      <ns4:ArrayOfWaypointDesc_2>
          <ns3:wrappedCoords>
            </ns1:Point>
        </ns3:WaypointDesc>
          <ns3:wrappedCoords>
            </ns1:Point>
        </ns3:WaypointDesc>
          <ns3:wrappedCoords>
            </ns1:Point>
        </ns3:WaypointDesc>
          <ns3:wrappedCoords>
            </ns1:Point>
        </ns3:WaypointDesc>
      </ns4:ArrayOfWaypointDesc_2>
      <ns4:ArrayOfRoutingOption_3>
        <ns3:RoutingOption xmlns:ns3="http://xroute.xserver.ptvag.com" parameter="ROUTE_LANGUAGE" value="EN" />
      </ns4:ArrayOfRoutingOption_3>
      <ns4:MatrixOptions_4 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
      <ns4:CallerContext_5>
        <ns2:wrappedProperties xmlns:ns2="http://baseservices.service.jabba.ptvag.com">
          <ns2:CallerContextProperty value="carfast" key="Profile" />
          <ns2:CallerContextProperty value="PTV_GEODECIMAL" key="CoordFormat" />
          <ns2:CallerContextProperty value="PLAIN" key="ResponseGeometry" />
        </ns2:wrappedProperties>
      </ns4:CallerContext_5>
    </ns4:calculateMatrixInfo>
  </soap:Body>
</soap:Envelope>
which leads to mentioned log entry and play a little with it.
And et voilà the passage
is the evil part.
:oops:
After removing this relict from earlier experiments with xRoute now I got in the log:
2017-03-23 20:32:31,618;DEBUG;com.ptvag.xserver.module.xroute.m0001;2792330f-7b14-4b8a-971d-994a3721c3d9;;;;Load high-performance routing network from the following file: <path-to-hpr-network-files>/carfast.chData
Hello Birk,
thanks for the deep drill into the topic!
What was the final computation time for xRoute+carFast(HPR)?
daxbin
Computing times for xRouteServer with HPR
Post by daxbin »
now the times are
xRoute   carfast   ×     625     625    7,8 s
which is satisfying for xRoute too.
BTW, the important point for me were not absolute numbers but to get HPR running which should lead to a significant reduction in the computing time.
Best regards, Birk
Just for your info:
There's a bugfix in xRoute 1.24.0.0:
„Fixed configuration switch to load high-performance routing networks on startup.”
So this might again speed up the calculation ;-)
Please do keep in mind:
The xRoute.calculateMatrixInfo call returns all the relations within the response. This means a lot of elements that have to be serialized. xDima.calculateDistanceTable returns just void when it is done, which is a lot faster to serialize. If you compare the 2 calls, there will always be an overhead difference because of this.
sure!
to check this you could take a look at the internal module time in the RequestTimes of the logs ;-)
Anyhow: if the user requires the complete info on clientside he would have to wait the 7.8seconds
or to use xDima's 1.8 seconds PLUS all the getDistPeriod-calls which would then raise additional time.
STRIKE!
daxbin
I used (asynchronous) xRoute.startCalculateMatrixInfo
Post by daxbin »
Hello Joost,
I have tried not to consider the transfer time of the relations from the xServer to the client.
My explanation for
the difference between xDima and xRoute was not the transfer time of the relations within the response because I did not use synchronous call xRoute.calculateMatrixInfo.
Instead, like mentioned in my first post
I used the asynchronous invocation in both cases for xDima and xRoute.
My assumption was that even in the way of asynchronous invocation the xRoute has to save the result in the job (so that client can fetch it later) which may be less efficient than xDima's way of storing relations. But its just an assumption.
Best regards, Birk
Edit: Just as an addition: Client and server are 100 KiB/s (speed) and 30 ms (ping) apart.
Edit2: @Bernd: Looking into server logs I can see only 2.5 seconds for xRoute. No idea where the rest of the 7.8 seconds is consumed. Perhaps there is an issue in my client which isn't easy to reason about.
