Manoeuvres long and lat infos
g.fiume
Post by g.fiume »
Is it possible to have the exact manoeuvres coordinates? I need long & lat infos about some kind of manoeuvres. I've tried to have this info reaching the correspondent node but in nodes struct I've only x-offset and y-offset.
Re: Manoeuvres long and lat infos
just use the manoeuvres array:
each manoeuvre is linked to
  • int routeListSegmentIdx: The index of the corresponding RouteListSegment.
which is linked to firstPolyIdx = index of the segments first x,y-Coordinate
this should clarify what you have to do to get the coordinates of a manoeuvre:
Route route = tour.route;
// determine the polygon points
PlainPoint[] arrPolygonPoints = route.polygon.lineString.wrappedPoints;
// identify the manoeuvre, e.g. the 1st one
RouteManoeuvre manoeuvre = route.wrappedManoeuvres[0];
// identify the manoeuvres segment
RouteListSegment segment = route.wrappedSegments[manoeuvre.routeListSegmentIdx];
// identify the segments polygon point
PlainPoint manoeuvrePoint = arrPolygonPoints[segment.firstPolyIdx];
