xTour Internet: different Tripduration with same request
Posted: Thu Feb 02, 2017 3:16 pm
Hello everybody,
we are using the xTour server on the internet and with the same request (via raw request runner) we get sometimes and sometimes .
If I run the request on my local xTour server, and I get always totalTourPeriod="39208" . When I change the request from profileName="dimaCar" to profileName="dimatruck" then I get a trou period of almost 14 hours.
My question is: why sometimes use xTour internet the truck profile, although we put in the request to use profileName="dimaCar"?
We have solved our problem (at least we believe to have solved) using deleteBeforeUsage="true" .
Is it possible that different account may use the same dima with ID=1? Or the dima 1 for account x is not the same as for account y?
Thank you in advance abd best regards!
Sebastiano
totalTourPeriod="39208" (i.e. ~10 hours)Code: Select all
totalTourPeriod="49028" , i.e. ~14 hours If I run the request on my local xTour server, and I get always totalTourPeriod="39208" . When I change the request from profileName="dimaCar" to profileName="dimatruck" then I get a trou period of almost 14 hours.
Sebastiano
