Route planned in spite of a closed road
VPlachy
Post by VPlachy »
Good morning,
I created a Windows application for route planning. When planning a route, it happens that I have a route planned in spite of a closed road (no entry). I can not to figure out which parameters I have set wrongly.
For example, bypass german town of Nauen
Thank you
Vladimir
Vladimír Plachý, DiS.
Re: Route planned in spite of a closed road
Hello Vladimir,
sounds like you successfully activated a specific feature layer (PTV_TrafficIncidents? PTV_TruckAttributes?) in the mapping call but not in the routing call.
If this is the case please ensure to use a valid profile XML snippet, e.g. to activate PTV_TruckAttributes (minimalistic example).
<Profile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http:///xroute/schema/XRouteProfile.xsd">
<GlobalSettings enableTimeDependency="true"/>
<Themes>
<Theme id="PTV_TruckAttributes" enabled="true"/>
</Themes>
</FeatureLayer>
<Course>
<AdditionalDataRules enabled="true"/>
</Course>
</Routing>
</Profile>
VPlachy
Post by VPlachy »
I am active in the calculation feature layer PTV_TruckAttributes. I use this XML code, but it still does not count correctly.
     <Themes>
      </Themes>
   </FeatureLayer>
  <Common coordinateFormat="PTV_MERCATOR" language="en" majorVersion="1" minorVersion="0" />
	<Vehicle>
		<Physical>
			<Drive driveType="MOTORIZED">
				<Emissions emissionClass="EURO_5" emissionTechnology="NONE" lowEmissionZoneType="GREEN" particleFilterInstalled="false" particleReductionClass="0"/>
				<Engine bioFuelRatio="0" cylinderCapacity="12000" fuelConsumption="4.5" fuelType="DIESEL"/>
			</Drive>
			<Weight emptyWeight="10000" loadWeight="15000" totalPermittedWeight="39998"/>
			<Axle axleLoad="11500" numberOfAxles="5"/>
			<Trailer emptyWeight="5000"/>
			<Dimension height="399" length="1799" width="254"/>
		</Physical>
		<Legal yearOfManufacture="2010">
			<LegalCondition isAuthorized="false" isDelivery="false" isEmergency="false" isMaintenance="false" isProject="false"/>
		</Legal>
		<Load hazardousGoodsType="NONE" loadType="GOODS" tunnelRestrictionCode="NONE"/>
		 <Speed maximumSpeed="255" speedForAirLineDistance="36">
                <SpeedRangeByNetworkClass maximumSpeed="80" minimumSpeed="55"/>
                <SpeedRangeByNetworkClass maximumSpeed="60" minimumSpeed="30"/>
                <SpeedRangeByNetworkClass maximumSpeed="55" minimumSpeed="23"/>
                <SpeedRangeByNetworkClass maximumSpeed="45" minimumSpeed="20"/>
                <SpeedRangeByNetworkClass maximumSpeed="40" minimumSpeed="18"/>
                <SpeedRangeByNetworkClass maximumSpeed="30" minimumSpeed="15"/>
                <SpeedRangeByNetworkClass maximumSpeed="12" minimumSpeed="7"/>
                <SpeedRangeByNetworkClass maximumSpeed="6" minimumSpeed="4"/>
            </Speed>
	</Vehicle>
	<Waypoint linkType="AREA_SEGMENTS" maximumDistanceToCombinedTransport="1000" maximumDistanceToSegment="5000">
		<LinkTypeConfiguration>
		  <Road headingTolerance="360" maximumDistanceForNetworkClass0="1000" maximumNetworkClass="7" minimumNetworkClass="0" onlyReachableRoads="false"/>
			<Smart checkNetworkClassOnlyForVias="true" maximumDistanceToMainNode="100" maximumDistanceToMainNodeForNetworkClass0="1500"/>
			<TollStation maximumDistance="1000"/>
			<RoadName maximumDistance="3000" maximumDistanceToMainNode="2000"/>
		</LinkTypeConfiguration>
	</Waypoint>
    <Course>
		<AdditionalDataRules enabled="true">
                <SegmentSpecific useBlockedForCarsAttribute="true" useBlockedForTrucksAttribute="true" useFerryDuration="true" useFerryLength="true" useRampAttribute="true" useSegmentLength="true" useSpeed="true" useTollForCarsAttribute="true" useTollForTrucksAttribute="true" useUrbanAttribute="true"/>
                <VehicleSpecific enabled="false">
                    <Malus combustibles="0" delivery="0" hazardousGoods="0" hazardousToWaters="0" maintenanceTrucks="0" preferredForHazardousGoods="0" preferredForTrucks="0" residential="0" restrictedTunnel="0" vehiclesWithTrailer="0"/>
                </VehicleSpecific>
        </AdditionalDataRules>
		<DynamicRouting breakCalculationPrecision="4294967295" dynamicTimeOnStaticRoute="false" layerName="" limitDynamicSpeedToStaticSpeed="true" useFreeFlowSpeed="false" useLegacyDynamic="false">
                <SpeedMapping baseSpeed="1" mappedSpeed="1"/>
                <SpeedMapping baseSpeed="10" mappedSpeed="10"/>
                <SpeedMapping baseSpeed="20" mappedSpeed="20"/>
                <SpeedMapping baseSpeed="30" mappedSpeed="30"/>
                <SpeedMapping baseSpeed="40" mappedSpeed="40"/>
                <SpeedMapping baseSpeed="50" mappedSpeed="50"/>
                <SpeedMapping baseSpeed="60" mappedSpeed="56"/>
                <SpeedMapping baseSpeed="70" mappedSpeed="61"/>
                <SpeedMapping baseSpeed="80" mappedSpeed="66"/>
                <SpeedMapping baseSpeed="90" mappedSpeed="69"/>
                <SpeedMapping baseSpeed="100" mappedSpeed="72"/>
                <SpeedMapping baseSpeed="110" mappedSpeed="73"/>
                <SpeedMapping baseSpeed="120" mappedSpeed="74"/>
                <SpeedMapping baseSpeed="130" mappedSpeed="75"/>
                <SpeedMapping baseSpeed="140" mappedSpeed="75"/>
                <DynamicTimeStep count="1" size="900"/>
        </DynamicRouting>
        <Maneuver considerTurningBans="true" uTurnCost="5000"/>
        <Violations>
            <SegmentBlockingViolations cost="50000" enabled="false"/>
        </Violations>
		<BasicDataRules>
			<Blockings blockedInWinterMalus="0" blockedMalus="2501" blockedTimeDependentMalus="0" oppositeDirectionInOneWayRoadMalus="2501"/>
                <Network rampMalus="0">
                    <MalusByNetworkClass malus="15"/>
                    <MalusByNetworkClass malus="2500"/>
                </Network>
				<Toll extraTollMalus="0" tollMalus="0" vignetteMalus="0"/>
				<SpecialAreas forbiddenLowEmissionZoneMalus="2500" minimumUrbanNetworkClass="2" residentialMalus="0" urbanMalus="0"/>
				<CombinedTransport ferryMalus="100" piggybackMalus="0"/>
         </BasicDataRules>
	</Course>
	</Routing>
</Profile>
I even tried your XML, and that does not work.
This is part of the code for route calculation.
ResultListOptions RsltListOptions = new ResultListOptions();
                RsltListOptions.binaryPathDesc = true;
                RsltListOptions.polygon = true;
                RsltListOptions.dynamicInfo = true;
                RsltListOptions.extSegments = true;
                RsltListOptions.featureDescriptions = true;
                RsltListOptions.nodes = true;
                RsltListOptions.speedLimits = true;
                RsltListOptions.segments = true;
                RsltListOptions.texts = true;
                RsltListOptions.detailLevel = DetailLevel.ALL;
                RsltListOptions.polygonElevationsSpecified = true;
                RsltListOptions.polygonElevations = true;
                RsltListOptions.tollManoeuvres = true;
                RsltListOptions.manoeuvres = true;
                RsltListOptions.manoeuvreGroups = true;
                RsltListOptions.brunnelManoeuvres = true;
                RsltListOptions.manoeuvreAttributes = true;
                RsltListOptions.urbanManoeuvres = true;
                RoutingOption[] RoutOption = new RoutingOption[11];
                RoutOption[0] = new RoutingOption();
                RoutOption[0].parameter = XrouteService.RoutingParameter.ROUTE_LANGUAGE;
                RoutOption[0].value = "CS";
                RoutOption[1] = new RoutingOption();
                RoutOption[1].parameter = XrouteService.RoutingParameter.COUNTRY_ENCODING;
                RoutOption[1].value = "ISO2";
                RoutOption[2] = new RoutingOption();
                RoutOption[2].parameter = XrouteService.RoutingParameter.START_TIME;
                RoutOption[2].value = sStartDate;
                RoutOption[3] = new RoutingOption();
                RoutOption[3].parameter = XrouteService.RoutingParameter.IS_DESTTIME;
                RoutOption[3].value = sIS_DESTTIME;
                RoutOption[4] = new RoutingOption();
                RoutOption[4].parameter = XrouteService.RoutingParameter.OPTIMIZATION;
                RoutOption[4].value = Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Optimisation));
                RoutOption[5] = new RoutingOption();
                RoutOption[5].parameter = XrouteService.RoutingParameter.GENERATE_EXTWAYPOINTS;
                RoutOption[5].value = "true";
                RoutOption[6] = new RoutingOption();
                RoutOption[6].parameter = XrouteService.RoutingParameter.ENABLE_DYNAMIC;
                RoutOption[6].value = "true";
                RoutOption[7] = new RoutingOption();
                RoutOption[7].parameter = XrouteService.RoutingParameter.DYNAMIC_PROFILE;
                RoutOption[7].value = "PTV_TruckAttributes";
                RoutOption[8] = new RoutingOption();
                RoutOption[8].parameter = XrouteService.RoutingParameter.SPEED_INFOS;
                RoutOption[8].value = "true";
                RoutOption[9] = new RoutingOption();
                RoutOption[9].parameter = XrouteService.RoutingParameter.ALLOW_SEGMENT_VIOLATIONS;
                RoutOption[9].value = "false";
                RoutOption[10] = new RoutingOption();
                RoutOption[10].parameter = XrouteService.RoutingParameter.GENERATE_EXTWAYPOINTS;
                RoutOption[10].value = "true";
                CountryInfoOptions CountryInfoOption = new XrouteService.CountryInfoOptions();
                CountryInfoOption.allEuro = false;
                CountryInfoOption.calculatePartTollCosts = true;
                CountryInfoOption.detailedTollCosts = true;
                CountryInfoOption.tollDate = DateTime.Now;
                CountryInfoOption.tollDateSpecified = true;
                CountryInfoOption.namedToll = true;
                CountryInfoOption.namedTollSpecified = true;
                CountryInfoOption.currencyDescription = true;
                CountryInfoOption.currencyDescriptionSpecified = true;
                CountryInfoOption.tollTotals = true;
                CountryInfoOption.tollTotalsSpecified = true;
                CountryInfoOption.waypointIndexInTollCostInfo = true;
                CountryInfoOption.waypointIndexInTollCostInfoSpecified = true;
  response2 = xRoute.calculateExtendedRoute(new calculateExtendedRouteRequest
                        ArrayOfWaypointDesc_1 = wayPoints,
                        ArrayOfRoutingOption_2 = RoutOption,
                        ResultListOptions_4 = RsltListOptions,
                        CountryInfoOptions_5 = CountryInfoOption,
                        CallerContext_6 = new PTVxServerInternet.XrouteService.CallerContext
                            wrappedProperties = new[]
                           new PTVxServerInternet.XrouteService.CallerContextProperty { key = "ProfileXMLSnippet", value = sNewXML}
Vladimír
meanwhile we reproduced the issue:
The blocking displayed in the map is a PTV_TrafficIncident (and not a TruckAttribute).
As traffic incidents are time dependent it is important to be aware of the reference time of both ROUTE and MAP:
If the map visualizes the current datetime as reference but the routing refers to a completely different time the route might seem to be invalid.
