Silverlight Map Control on GitHub
Posted: Tue Aug 26, 2014 4:34 pm
Hello there,
as there are still some guys using Microsoft Silverlight (which i quite understand as it's still quite unbeatable as Dev-Tool), i've put our code sample for xServer /w SL on GitHub.
https://github.com/oliverheilig/SilverMap
SilverMap is the chunky little brother of our xServer .NET SDK. It's not as fully-featured as xServer.NET, but we publish it as source code, so you can extend it at your will. It is configured to use our hosted xServer Internet out-of-the box (you can get a trial token here http://xserver.ptvgroup.com/en-uk/produ ... rnet/test/), but you can also adopt it to work with your on-premise Installation.
You can play with the the samples here
http://80.146.239.139/SilverMap/SilverMapTestPage.aspx
