Optimizing a tour takes very long
Posted: Fri Oct 28, 2016 2:04 pm
Hi All,
I'd like to optimize a tour with a few loadingpoints.
Optimization should calculate the shortest route by reordering the loadingpoints to the correct position.
Currently I am using "planBasicTours" to do so, but this is very slow ... it takes between 20 and 30 seconds to deliver a result. I doubt this is a normal response time, is it?
Here you can see one of these requests performing bad, do you have a clue what is going wrong or what could be done better? Eventually I missunderstood what "planBasicTours" is doing and there is another possibility to achieve my goal?
Thanks in advance!
Marcel
Thanks in advance!
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<ns2:planBasicTours xmlns="http://common.xserver.ptvag.com" xmlns:ns2="http://types.xtour.xserver.ptvag.com" xmlns:ns3="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns4="http://exception.core.jabba.ptvag.com" xmlns:ns5="http://baseservices.service.jabba.ptvag.com" xmlns:ns6="http://xtour.xserver.ptvag.com">
<ns2:ArrayOfTransportOrder_1> <ns6:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns6:TransportDepot" trailerLoadingForbidden="false" id="1">
<ns6:deliveryQuantities>
<ns6:wrappedQuantities>
<ns3:Int>0</ns3:Int>
</ns6:wrappedQuantities>
</ns6:deliveryQuantities>
<ns6:transportPoint coDriverRequired="false" openingIntervalConstraint="START_OF_SERVICE" allowServiceSplit="true" useServicePeriodForRecreation="false" servicePeriod="0" tourSection="0" id="1" description="DAIMLWOERT767">
<ns6:location>
<point y="49.05186" x="8.27874"/>
</ns6:location>
</ns6:transportPoint>
</ns6:TransportOrder> <ns6:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns6:TransportDepot" trailerLoadingForbidden="false" id="2">
<ns6:transportPoint coDriverRequired="false" openingIntervalConstraint="START_OF_SERVICE" allowServiceSplit="true" useServicePeriodForRecreation="false" servicePeriod="0" tourSection="0" id="2" description="HDARMS642">
<ns6:location>
<point y="49.88275" x="8.62595"/>
</ns6:location>
</ns6:TransportOrder> <ns6:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns6:TransportDepot" trailerLoadingForbidden="false" id="3">
<ns6:transportPoint coDriverRequired="false" openingIntervalConstraint="START_OF_SERVICE" allowServiceSplit="true" useServicePeriodForRecreation="false" servicePeriod="0" tourSection="0" id="3" description="MOSOLILLIN75411">
<ns6:location>
<point y="48.95487" x="8.94174"/>
</ns6:location>
</ns6:TransportOrder> <ns6:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns6:TransportDepot" trailerLoadingForbidden="false" id="4">
<ns6:transportPoint coDriverRequired="false" openingIntervalConstraint="START_OF_SERVICE" allowServiceSplit="true" useServicePeriodForRecreation="false" servicePeriod="0" tourSection="0" id="4" description="MITZEEBR838">
<ns6:location>
<point y="51.3265" x="3.22011"/>
</ns6:location>
</ns6:TransportOrder> <ns6:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns6:TransportDepot" trailerLoadingForbidden="false" id="5">
<ns6:transportPoint coDriverRequired="false" openingIntervalConstraint="START_OF_SERVICE" allowServiceSplit="true" useServicePeriodForRecreation="false" servicePeriod="0" tourSection="0" id="5" description="TERMIZEEBR838">
<ns6:location>
<point y="51.31417" x="3.23854"/>
</ns6:location>
</ns6:TransportOrder> </ns2:ArrayOfTransportOrder_1><ns2:ArrayOfDepot_2> <ns6:Depot id="1" description="AGDÜSSE4041">
<ns6:location>
<point y="51.26017" x="6.79475"/>
</ns6:location>
</ns6:Depot><ns6:Depot id="2" description="ICOZEEBR838">
<ns6:location>
<point y="51.29413" x="3.22829"/>
</ns6:location>
</ns6:Depot></ns2:ArrayOfDepot_2>
<ns2:Fleet_3>
<ns6:wrappedVehicles>
<ns6:Vehicle ignoreIntermediatePeriodBeforeFirstTour="false" id="301" toursMustFitIntoSingleOperatingInterval="false" coDriverStatus="NEVER" ignoreTransportPointServicePeriod="false" dimaId="1" isPreloaded="false" depotIdStart="1" depotIdEnd="2" >
<ns6:capacities>
<ns6:wrappedCapacities>
<ns6:Quantities>
</ns6:Quantities>
</ns6:wrappedCapacities>
</ns6:capacities>
<ns6:restrictions maxTourCountPerChain="1"/>
</ns6:Vehicle>
</ns6:wrappedVehicles>
</ns2:Fleet_3>
<ns2:PlanningParams_4 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ns6:StandardParams" availableMachineTime="30">
<ns6:wrappedDistanceMatrixCalculation>
<ns6:DistanceMatrixCalculation xsi:type="ns6:DistanceMatrixByRoad" profileName="truckfast" deleteAfterUsage="true" deleteBeforeUsage="true" dimaId="1"/>
</ns6:wrappedDistanceMatrixCalculation>
</ns2:PlanningParams_4>
<ns2:CallerContext_6>
<ns5:wrappedProperties>
<ns5:CallerContextProperty value="Test-Request" key="TransactionId"/>
<ns5:CallerContextProperty value="OG_GEODECIMAL" key="CoordFormat"/>
</ns5:wrappedProperties>
</ns2:CallerContext_6>
</ns2:planBasicTours>
</soap:Body>
</soap:Envelope>
Marcel
