Missing ObjectInfos for BlocksCar / BlocksTruck
Posted: Fri Oct 07, 2016 11:28 am
Hello community,
I'm dealing with the following issue, maybe somebody of you has a hint how to resolve it:
Given conditions:
Given conditions:
- a binary TruckAttributes file that contains the regular TruckAttributes plus some customized BlocksCar and BlocksTruck infos.
- the two categories are displayed in the map properly (red circle with white inner space)
- the map response does not return ObjectInfos : creating proper tooltips is not possible
- refering to the segment category during a routing is handeled as it should be: the route takes a detour if violations are forbidden. If violations are allowed (additional costs=0) the segments are in use and the responses "segmentAttributes.additionalRE" and "segmentAttributes.violations" mention the BLOCKS_CAR and BLOCKS_TRUCK
