Considering totalPermittedWeight problem
qsku
Post by qsku »
I have a problem to make xServer consider totalPermittedWeight while routing.
For testing purposes I'm using Request Runner at https://xroute-eu-n-test.cloud.ptvgroup ... quest.html
I'm passing totalPermittedWeight='7500' within ProfileXMLSnippet.
In spite of this parameter I'm getting segments marked by maxWeight=3500 in the response.
Why does it work that way?
Here is my test request:
  "waypoints": [
      "$type": "WaypointDesc",
      "linkType": "NEXT_SEGMENT",
      "fuzzyRadius": 0,
      "coords": [
          "$type": "Point",
          "point": {
            "$type": "PlainPoint",
            "x": 5.904121700218979,
            "y": 49.91983561437948
      "fuzzyRadius": 0,
      "coords": [
          "$type": "Point",
          "point": {
            "x": 5.939734590555138,
            "y": 49.93496515392465
  "options": [],
  "exceptionPaths": [],
  "details": {
    "manoeuvres": false,
    "texts": false,
    "nodes": false,
    "binaryPathDesc": false,
    "polygon": true,
    "detailLevel": "BORDERS",
    "dynamicInfo": false,
    "segments": true,
    "segmentAttributes": false,
    "manoeuvreAttributes": false,
    "brunnelManoeuvres": false,
    "urbanManoeuvres": false,
    "manoeuvreGroups": false,
    "tollManoeuvres": false,
    "boundingRectanglesC": 0,
    "boundingRectanglesOffset": 0,
    "totalRectangle": false,
    "featureDescriptions": true
  "callerContext": {
    "properties": [
        "key": "ResponseGeometry",
        "value": "PLAIN"
        "key": "CoordFormat",
        "value": "OG_GEODECIMAL"
        "key": "ProfileXMLSnippet",
        "value": "<?xml version='1.0' encoding='UTF-8'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation=\"http:///xroute/schema/XRouteProfile.xsd\"><Routing majorVersion='2' minorVersion='0'><Vehicle><Physical><Weight totalPermittedWeight='7500'/></Physical></Vehicle><Course><AdditionalDataRules enabled='true'><VehicleSpecific enabled='true'><Malus residential='2501'/></VehicleSpecific></AdditionalDataRules></Course></Routing><FeatureLayer majorVersion='1' minorVersion='0'><Themes><Theme id='PTV_TruckAttributes' enabled='true'/></Themes></FeatureLayer></Profile>"
Edit by Joost: added code blocks for readability
Re: Considering totalPermittedWeight problem
You are not referencing a specific vehicle profile for base values in you request. xRoute will then use the default profile witch is a carfast. Looking at the weight value you should reference a truckfast for more useful base values. When I tried your request with a truckfast profile, it is routing around the restriction.
  "waypoints": [
      "fuzzyRadius": 0,
      "coords": [
          "$type": "Point",
          "point": {
      "fuzzyRadius": 0,
      "coords": [
          "$type": "Point",
          "point": {
  "options": [],
  "details": {
    "texts": false,
    "nodes": false,
    "polygon": true,
    "segments": true,
  "callerContext": {
    "properties": [
        "value": "PLAIN"
        "key": "Profile",
        "value": "truckfast"
