What is the usecase behind clustering?
Posted: Mon Jun 30, 2014 9:21 am
Hello together,
this posting is just to give you a quick intro into the usecases of xCluster:
Clustering is a strategic usecase that has impact on long term decisions. Imagine a set of several hundred customers located in your area of responsibility.
Now quite often you assign these customers to specific sets whether it is a postcode region (quite simple because the customers address contains the cluster ID) or a weekday... Check the attached image:
it demonstrates the assignment of a given number of locations to the clusters 1,2,3.
Besides the ID each location has two important properties (in the context of clustering):
So much for now,
I hope this short intro opens your mind to understand the benefits provided by xCluster,
Regards Bernd
- the coordinates
- the quantity (e.g. the revenue, the service period or some other measurement...)
- a cluster is compact: cluster areas shouldn't overlap from a geographical point of view.
- the clusters are balanced: the sum of the quantities of a clusters elements is almost equal in all the clusters, e.g. because you want to have equal total revenue in all areas
- You have a list of visits to be scheduled over a given period (e.g. 24 weeks) aka horizon
- For each visit you have some additional constrains such as
- on which weekday is it possible to visit this customer"?
- is there a specific visiting pattern (periodical visit each 4 weeks...)
So much for now,
Regards Bernd
