TOKEN usage via the arrival board
Posted: Mon May 09, 2016 6:48 am
Hello together,
these days I've been asked "whose token will be used when I'm heading for a ramp chosen via the arrival board?". The answer is simple: In this case the tour is invoiced via the token of the board owner.
Re: TOKEN usage via the arrival board
Posted: Mon May 09, 2016 7:52 am
by Olaf.Neumann
when you are heading to a ramp chosen in PTV Driver&Arrive Driver App the token assigned to the ramp in PTV Drive&Arrvie ArrvialBoard will be used. Yes, tour is invoiced via token of the board owner.
Olaf
