Traffic and Bandwidh calculation
How much network traffic generates the connection from the client to PTV X Server INTERNET?
That means:
To calculate our needed Internet Bandwidth in our planned Data Center (Hosting Contract), we need to know
how much traffic the quantity of X queries at the same time generates.
For this purpose we have to calculate the average traffic per query.
For example:
• We have 50 Clients.
• Every Client is going to send max. 1 Query per minute.
• So we need 50 times the theoretical calculated amount of traffic per Query.
Would be very helpful to know these bench mark.
Many Thanks
Lars Sert
Re: Traffic and Bandwidh calculation
Hello Lars,
yeah - that is definetly a challenging question. I already placed it at several departments (internal cloud providers, development, product management).
In fact we do not have benchmarks that contain information about required bandwith - obviously our internal testing suite is based on a sufficient infrastructure. From a technical point of view the required XML or JSON documents sizes vary a lot depending on various factors. I'll comment them service by service - but the conclusion is more or less "you need to test it based on your own functional requirements":
- xlocate.findAddress: a simple geocoding call about 2KB, the response with about 10 hits produces about 20KB - which is ridiculous.
- xlocate.findLocation: s a simple reverse geocoding also about 2KB request, 20KB response (I assume that you limit the result hit number)
- xRoute.calculateExtendedRoute: response size depends on geographic size of the track, requested response elements and response geometry style (WKB prefered). Example: input size <3KB. International track (Luxemburg to Warscaw, 1300km) incl. polygon and texts produces about 2MB response (uncompressed). Small track (<50km) is less than 100KB response.
- xMap.renderMap: pure basesemap request (256x256, PNG) less than 2KB (bigger if you request additional POI info in the map). Response size is about 30KB. In a tiled environment you may require a matrix of tiles for a large fullscreen experience, e.g. 6x8 tiles = about 50(!) of them. Depending on the caching effects this is like requesting 50x30KB = 1.5MB
- xTour.planBasicTours: hard to determine - some requests deal with 1 vehicle and less than 10 orders while others try to dispatch 2000 orders over 100 vehicles... can't give a concrete value. But: with the larger scenarios the bottleneck is no longer the network bandwith but the the computation time in the backend. SO this is when it comes to asynchronuous protocols.
- do not request what you don't need (xroute.ResultListOptions, proper method)
- use WKB format whenever it is possible
- use JSON if possible (my tests were based on SOAP)
