API Loading mechanism
Posted: Wed Feb 03, 2016 3:29 pm
by JonasAJ
I’m currently trying to implement a simple Map in our Product, which seemed pretty easy thanks to the Code Sample Browser. But our framework only allows me to hand over one external API. You already use two scripts in the Basic Map rendering example, my question would be, if there is a API which summarized all the needed API’s (like xMap, sample.min, xRoute and so on) in one together?
Best Regards,
Jonas
Re: API Loading mechanism
Posted: Wed Feb 03, 2016 3:35 pm
Hello Jonas,
I forwarded this request to our developers (knowing that you are dealing with a specific condition: web environment with JavaScript). Hopefully they'll answer asap on their own.
Answering your question on a generic level using C# / .NET I can answer that it is possible to merge several WSDL files into a single shared C# file using the command line tool WSDL.EXE which is part of Visual Studio. Probably no solution for you but an approach for others who might take a look at your question.
If you don't get an answer within the next days please get back to me (in person) and I'll stress it internally.
Posted: Thu Feb 04, 2016 10:06 am
Meanwhile I received feedback from DEV (regarding the JavaScript and LEAFLET approach):
We do not provide a single package for the approach described by you. This is because we create a single client for each available backend module and those clients are bundled afterwards during the automated build process.
There is a workaround: process the requests without the PTV client. This procedure is described in the developers guide at Developers Guide => Programming Environment => Generating Clients => JavaScript.
http://xserver.ptvgroup.com/fileadmin/f ... t%7C_____2
Best regards and thanks to Matthias David,
Posted: Thu Feb 04, 2016 4:40 pm
and here is some more valuable food...
http://xserver.ptvgroup.com/en-uk/cookb ... ping-apis/
Thanks to Oliver!!!
