Use VIA point FUZZY
VPlachy
Use VIA point FUZZY
Post by VPlachy »
I have a problem with the calculation of the route using point type FUZZY. When I use this type of item I will return to me when calculating error "This service-method does not support vehicle- or routing-options".
I tried to set possible and impossible, but without result.
Please can you give me information about what is needed to have with this type of set point?
csharp code
          ViaType vt = new ViaType( );
            vt.viaType = ViaTypeEnum.FUZZY;
            for (int x = 0; x < CalculationWayPointsList.Count; x++)
                wayPoints[x] = new WaypointDesc();
                if (CalculationWayPointsList[x].Type == "M")
                    wayPoints[x].linkType = LinkType.FUZZY_LINKING;
                    wayPoints[x].viaType = vt;
                else
                    wayPoints[x].linkType = LinkType.AUTO_LINKING;
                wayPoints[x].fuzzyRadius = 10000;
                wayPoints[x].wrappedVehicleOptions = VehOption;
                clickPoint = new PTVxServerInternet.XrouteService.PlainPoint { x = CalculationWayPointsList[x].Mercator_Longitude, y = CalculationWayPointsList[x].Mercator_Latitude };
                wayPoints[x].wrappedCoords = new XrouteService.Point[] { new XrouteService.Point { point = clickPoint } };
               ResultListOptions RsltListOptions = new ResultListOptions();
                RsltListOptions.binaryPathDesc = true;
                RsltListOptions.polygon = true;
                RsltListOptions.dynamicInfo = true;
                RsltListOptions.extSegments = true;
                RsltListOptions.featureDescriptions = true;
                RsltListOptions.nodes = true;
                RsltListOptions.speedLimits = true;
                RsltListOptions.segments = true;
                RsltListOptions.texts = true;
                RsltListOptions.detailLevel = DetailLevel.ALL;
                RsltListOptions.polygonElevationsSpecified = true;
                RsltListOptions.polygonElevations = true;
                RsltListOptions.tollManoeuvres = true;
                DateTime dt =  Convert.ToDateTime(dtpStartTime.Value).AddHours(-1);
                string sStartDate = String.Format("{0:yyyy-MM-dd}", dt) + "T" + String.Format("{0:HH:mm}", dt) + "01:00";
                string sIS_DESTTIME = "true";
                if (cbTypJizdyCas.SelectedIndex > 0)
                    sIS_DESTTIME = "false";
                RoutingOption[] RoutOption = new RoutingOption[8];
                RoutOption[0] = new RoutingOption();
                RoutOption[0].parameter = XrouteService.RoutingParameter.ROUTE_LANGUAGE;
                RoutOption[0].value = "CS";
                RoutOption[1] = new RoutingOption();
                RoutOption[1].parameter = XrouteService.RoutingParameter.COUNTRY_ENCODING;
                RoutOption[1].value = "ISO2";
                RoutOption[2] = new RoutingOption();
                RoutOption[2].parameter = XrouteService.RoutingParameter.START_TIME;
                RoutOption[2].value = sStartDate;
                RoutOption[3] = new RoutingOption();
                RoutOption[3].parameter = XrouteService.RoutingParameter.IS_DESTTIME;
                RoutOption[3].value = sIS_DESTTIME;
                RoutOption[4] = new RoutingOption();
                RoutOption[4].parameter = XrouteService.RoutingParameter.OPTIMIZATION;
                RoutOption[4].value = Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Optimisation));
                RoutOption[5] = new RoutingOption();
                RoutOption[5].parameter = XrouteService.RoutingParameter.GENERATE_EXTWAYPOINTS;
                RoutOption[5].value = "true";
                RoutOption[6] = new RoutingOption();
                RoutOption[6].parameter = XrouteService.RoutingParameter.ENABLE_DYNAMIC;
                RoutOption[6].value = "true";
                RoutOption[7] = new RoutingOption();
                RoutOption[7].parameter = XrouteService.RoutingParameter.DYNAMIC_PROFILE;
                RoutOption[7].value = "PTV_TruckAttributes";
 string sXML = Properties.Settings.Default.CalculateProfile;
                string sNewXML = String.Format(sXML,
                                               Convert.ToString(chbTruckAtributes.Checked),
                                                emission_class,
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Cylinder_Capacity * 1000.0)),
                                                fuel_type,
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Unload_Weight * 1000.0)),
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Total_Weight * 1000.0)),
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Number_of_Axles)),
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Unload_Trailer_Weight * 1000.0)),
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Height * 100.0)),
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Length * 100.0)),
                                                Convert.ToString(Convert.ToInt32(Selected_VehicleProfileList.Width * 100.0))
                calculateRouteResponse response = xRoute.calculateRoute(new calculateRouteRequest
                    ArrayOfWaypointDesc_1 = wayPoints,
                    ArrayOfRoutingOption_2 = RoutOption,
                    ResultListOptions_4 = RsltListOptions,
                    CallerContext_5 = new PTVxServerInternet.XrouteService.CallerContext
                        wrappedProperties = new[]
                           new PTVxServerInternet.XrouteService.CallerContextProperty { key = "ProfileXMLSnippet", value = sNewXML }
Thank you.
Vladimir
Re: Use VIA point FUZZY
Hello Vladimir,
I assume the issue is caused by an invalid combination of parameters, e.g. a mixture of FuzzyLinking stops AND dynamic routing at the same time (which doesn't fit our data model).
For a proper individual handling I recommend that you
  • capture the XML request
  • get in touch with support
PS: for a quick reproduction your source isn't sufficient - this is why we need the XML or JSON
I think I saw the error in your code:
This is not allowed for fuzzy points. See also:
http://xserver.ptvgroup.com/fileadmin/f ... ypointDesc
It explains when vehicleOptions attribute is allowed on a waypoint.
