Calculate distance and time between maneouvres and segments
Patricia
Post by Patricia »
Is it posible calculate the distance and time between two segments of a route? and also, Is it posible calculate the distance and time between Maneouvres of a route?
I'm using CalculateExtendedRoute for get Route between two or more waypoints.
Thanks in advance.
Re: Calculate distance and time between maneouvres and segme
Hello Patricia,
you can derive the required information from the various arrays that are part of the result "route" object:
http://xserver.ptvgroup.com/fileadmin/f ... %7C_____58
It contains several arrays that are cross referencing each other.
A spontaneous recommendation from my side is
  • The distance between two segments segment[index1] and segment[index2] is
    distance := route.segments[index2].accDist - route.segments[index1].accDist
  • The distance between two maneouvres is based on the manouvres segments:
    distance := route.segments[manoeuvres[index2].routeListSegmentIndex].accDist - route.segments[manoeuvres[index1].routeListSegmentIndex].accDist
