Optiflow - breaks setup
Posted: Wed May 13, 2026 1:29 pm
by CAPcargo
If we want to map the old xServer break configuration to the new Optiflow structure, would the following interpretation be correct?
For driving breaks:
  • Optiflow/Vehicles/breaks/driving/maximumDrivingDuration
is actually mapped to:
  • xServer/Fleet/Driver/configurableWorkingHours/breakRule/maximumDrivingTimeBetweenBreaks
And consequently:
Optiflow/minimumBreakDurations <-- maps to --> xServer/breakTime
with the difference that in Optiflow minimumBreakDurations is an array and the break duration can be split into multiple parts according to the configured sequence.
The same logic would also apply to working time rules in parallel:
  • maximumWorkingDuration
  • maximumWorkingTimeBetweenBreaks
So, from my understanding, a simple xServer break rule with a single breakTime value would basically map to an Optiflow configuration containing a single-element minimumBreakDurations array.
Is this the intended migration approach, or are there important differences that should be considered?
Thank you in advance.
Marko Arsovski
CAPcargo
Re: Optiflow - breaks setup
Posted: Fri May 15, 2026 11:28 am
Here's MIRA's feedback:
Your interpretation is correct. Here's a confirmation with the key nuances:
Mapping Validation
xServer (old)PTV OptiFlow (new)Match?
breakRule.maximumDrivingTimeBetweenBreaksbreaks.driving[].maximumDrivingDuration✅
breakRule.breakTime (driving) breaks.driving[].minimumBreakDurations ✅
breakRule.maximumWorkingTimeBetweenBreaks breaks.working[].maximumWorkingDuration ✅
breakRule.breakTime (working) breaks.working[].minimumBreakDurations ✅
Your conclusion is correct: a simple xServer rule with a single breakTime value maps to a single-element array in minimumBreakDurations.
Example migration
xServer → OptiFlow
maximumDrivingTimeBetweenBreaks: 16200 → maximumDrivingDuration: 16200
breakTime: 2700 → minimumBreakDurations: [2700]
:!: Important Differences to Consider
Aspect xServer PTV OptiFlow
Break splitting Separate configuration (if supported) Built into minimumBreakDurations as array: [900, 1800] = 15 min then 30 min
Multiple rules Typically one driving + one working rule Arrays — you can stack multiple driving and/or working rules simultaneously
Counter reset After break completes After the last element in minimumBreakDurations is completed, the counter resets and the full sequence starts again
Duration unit Depends on xServer version (seconds or HH:MM:SS) Always seconds (integer)
Daily rest / max total driving Part of configurableWorkingHours ❌ Not available in break settings — use vehicle.workingHours (shift start/end) as a proxy
Migration Checklist
  • Simple 1:1 rule → Single-element array. Your mapping is correct.
  • Split breaks → If xServer had a split break config (e.g. 15+30 min), migrate to multi-element array: "minimumBreakDurations": [900, 1800]
  • Multiple break tiers → If xServer had separate rules for different thresholds (e.g. short break after 4.5h, longer break after 6h), use multiple entries in the working or driving array:
    "driving": [
      { "maximumDrivingDuration": 16200, "minimumBreakDurations": [2700] }
    "working": [
      { "maximumWorkingDuration": 21600, "minimumBreakDurations": [1800] },
      { "maximumWorkingDuration": 32400, "minimumBreakDurations": [2700] }
  • Daily rest periods → Cannot be migrated to break settings. If xServer enforced daily rest, this must be handled via shift constraints (workingHours.earliestStart / latestEnd).
  • Max total driving time → Not enforceable through breaks. The maximumDrivingDuration only controls when a break is triggered, not the total cap.
So in summary: yes, your migration approach is the intended one. The main upgrade is that PTV OptiFlow gives you more flexibility (split breaks, stacked rules) — but loses the daily rest / total driving cap features that would need to be approximated through shift boundaries.
