Route Optimization API - Api Changes 1.59.0 (20.04.2026)
Posted: Mon Apr 20, 2026 1:55 pm
Route Optimization OptiFlow API1.59.0FEATURE20.04.2026Added availability windows to resources. Deprecated resource ids on routes in favor of a more generalized object.
Route Optimization OptiFlow API1.59.0FEATURE20.04.2026Added vehicle-charging station combination constraints.
I also asked PTV MIRA for the new features:
Two new features were introduced:
1. Availability Windows for Resources
Resources now support availability windows — time-based slots that define when a resource is available. This allows modeling scenarios like:
  • A shared truck that is only available in the morning shift (06:00–14:00) and again in the evening (18:00–22:00)
  • Equipment or drivers with specific working schedules
Additionally, the way resources are referenced on routes has changed: the previous resourceIds field on routes is deprecated in favor of a more generalized object structure (resources array with id and availabilityId), allowing routes to reference specific availability windows of a resource.
Input fields:
  • resources[].availabilities[] — array of availability windows with id, earliestStart, latestEnd
  • routes[].resources[] — new object format with id and availabilityId (replaces deprecated routes[].resourceIds[])
2. Vehicle–Charging Station Combination Constraints
A new combination constraint type allows controlling which vehicles can use which charging stations. This enables scenarios like:
  • Restricting certain charger types to specific vehicle categories (e.g., only heavy trucks can use high-power DC chargers)
  • Preventing vehicles from using incompatible charging infrastructure
  • Modeling proprietary charging networks accessible only to certain fleet segments
Input field:
  • constraints.combinations.vehicleChargingStation[] — with types CHARGING_STATION_REQUIRES_VEHICLE, VEHICLE_REQUIRES_CHARGING_STATION, and FORBIDDEN_COMBINATION, using vehicleCategory and chargingStationCategory matchers
Full details: route-optimization-optiflow-api/api-changes
