'strange' tourEventTypes 'Wait' in certain response (effect of PTV_TrafficIncidents)
Posted: Tue Feb 17, 2026 12:12 pm
by marius.vladutoiu
I have the following issue: I am running an xroute for a roundtrip, going from one start address to 2 addresses, and then coming back (see attached reques and response).
I am not 100% sure, but it looks like the issue I am having only happens when the PTV_TrafficIncidents layer is enabled.
It is true, that the 2 addresses are in a mountain area, where there are some time-dependent restrictions (I can see them when looking at the map).
However, I am not sure how that plays a role in this issue: when the response comes, it contains 2 tourEventTypes 'Wait' of duration exactly 2703 seconds each (this number in itself is strange, since it's 45 minutes and 3 seconds) and always placed between 'Driving' tourEventTypes.
I understand how the 'Driving' events would have such long durations, even if very little distance, because of the TrafficIncidents (time-dependent restrictions) in the area.
But I don't understand the purpose of the 'Wait' events of this strange duration, and their placement in between Driving events.
Can you please help in how to interpret this response?
Marius
Re: 'strange' tourEventTypes 'Wait' in certain response (effect of PTV_TrafficIncidents)
Posted: Tue Feb 17, 2026 12:39 pm
The route is taking combined transport during the waiting event. The driver is then not driving and most of the times it can't be used as a break so waiting is the correct event for what is going on.
I figured this out by also ask for the segment back and look for the segment that had the ID reference in it's eventIndeces property and I found:
      "distance": 0,
      "travelTime": 2703,
      "travelSpeed": 0,
      "trafficDelay": 0,
      "violated": false,
      "eventIndices": [
        6
      "type": "COMBINED_TRANSPORT",
      "combinedTransport": {
        "name": "Furka",
        "type": "RAIL",
        "duration": 2703,
        "start": {
          "name": "Realp",
          "country": "CH",
          "coordinate": {
            "x": 8.5028062755,
            "y": 46.597683661
        "destination": {
          "name": "Obergoms",
          "country": "CH",
          "coordinate": {
            "x": 8.3430719887,
            "y": 46.531307915
        "permissions": {
          "cars": true,
          "vans": true,
          "trucks": true
Posted: Tue Feb 17, 2026 1:08 pm
by marius.vladutoiu
Hello Joost,
Thanks for the quick reply. If I understand you correctly, the 'Wait' is actually the duration of the 'combined_transport', in this case 'rail' as the only means of transport to actually get to the address, which could not be classified as 'driving'.
Additional questions, please:
(1) Can you confirm that 'combined_transport' is only related to PTV_TrafficIncidents layer? Because, if I use the same request, but just set the PTV_TrafficIncidents = false, the 'Wait' event is not triggered anymore in the response.
(2) Or can you think of any other situation where this 'Wait' event would be inserted (other than 'combined_transport')?
Posted: Tue Feb 24, 2026 10:24 am
Hello Marius,
the involved PTV_TrafficIncidents layer brought some blockings into the story that made the combined transport to appear as a faster alternative compared to what happens without the layer. I recommend to define a session with us to replay and explain the story.
PS you can elaborate the traffic conditions with this showcase
time considerated blockings in the area
