Matrix Routing API - Api Changes 1.9.38 (13.01.2026)
Posted: Tue Jan 13, 2026 12:45 pm
Also check this blog post about Synchronous Time-Dependent Matrix: Traffic-Aware Routing now available
Matrix Routing API1.9.38FEATURE13.01.2026Using the options 'startTime' and 'trafficMode', a time-dependent matrix is calculated with the 'calculateMatrix' operation.
Matrix Routing API1.9.38BUGFIX13.01.2026Fixed request validation of the operation 'getRouteId'. Now bad request (400) is returned when the locations array is empty or not specified at all.
Check the following pages, too: Here are also some demo results:
  • Start time given, SYNC mode, TrafficMode=REALISTIC
  • Calculation time of 500² matrix (coordinates in the closer area of Vienna: 6.5 secs
  • Calculation time of 155² matrix exceeding the distance limit (coordinates in the wider area around Berlin): 8.0 secs
BIG THANKS to the team for this release!
